Pushrod help
Pushrod help
I have a set of MMS stage 2 heads that were milled .030
Does anyone know what size pushrods I will need for this setup with an aftermarket cam?
Cam specs: 227.09/226.12, .579/.580 on 113
Thanks guys!
Thanks guys!
I dont have a pushrod checking tool or else I'd use it, someone said it may be 7.35" but he wasnt sure.
Plus when I do my H/C swap, I wont have time to wait on a tool to get here so i can check the length needed and then have to wait MORE time for a set of pushrods to get here. This is my DD.
If anyone has a similar setup, please share what length of pushrods you are using.
Buy the length checker when you order the heads/cam and after you measure have the rods overnighted. Or rent a car for a day, you should plan for bugs to happen anyway, its a bad idea to try to pull off a head/cam swap in a day with no backup for a DD.
Might as well get it right the first time rather than playing guessing games.
Who is grinding that cam and what size head gaskets are you going to use?
Hey guys! Take it easy on him. He bought the cam from me and the heads from another member and I told him to post here because I didnt know the answer. I also told him he would get replies saying buy a checker and others suggesting a stock length -.030" but someone could have had an aftermarket cam and the same heads. brad8266, I remember when you used to ask questions like this.......and do not ******* say it never happened. A helpful reply would be whatever stock pushrod length is: stock pr - .030=7.xxx. That might be a little too much to ask from all the self proclaimed geniuses answering every thread on LS1tech, but after stating a friendly answer like that......you might HIGHLY suggest a pushrod length checking tool rather than jumping down his throat and putting some ****** *** bullshit in your sig. Every application is different but the same components may have been used by a viewer that could tell him the answer and save $20. Also, this is an actual application not somebody asking about a theoretical setup like every 9 out of 10 threads. WS6nJAX, i have traded with you before and you answered helpfully, just like in your trading. Thank you and if someone has a helpful reply......please let this guy know because he is great to deal with and not a know-it-all.
Originally Posted by brady346
brad8266, I remember when you used to ask questions like this.......and do not ******* say it never happened. .
He asked a question and I gave him an appropriate response which included the proper way of going about finding the right length pushrods. Well maybe i should have just said 7.4 will work since that what everyone else with noisy *** valvetrains uses. But no instead I try to tell him to do it the right way and you jump in and feel the need to take a few shots at me over nothing.
I put it in my sig since it gets asked so much, maybe ill just make a sticky instead, will that make you feel much better?
Please step off my nuts from now on.
I think a sticky would be more appropriate than making an example out of his thread and putting it in your sig. Thanks. ......sorry
Okay, bought a PR length checker... next question... figured I'd keep it in this post to consolidate the answers... save a little bandwidth
How thick of a head gasket will I have to go for with these heads? Or does that matter?
Example. You use the old stock gasket for the clay test and the old gasket is .052 thick. You slap it together and the clay measures .120 intake/.130 exhaust. That means you can safely run a .030 thinner gasket on that setup, although a .030 thinner gasket would not be practial. So in that case you would just run a .040 head gasket which would leave total PTVC .108intake/.118 exhaust.
So then order the head gasket and do a final assembly, then use you PR checker to get the proper length for for final assembled engine.
3 Answers...
1- get the checker
2- get the checker
and
3- Did you get the checker?
Or else...
https://ls1tech.com/forums/showthrea...ght=Valve+tick
1- get the checker
2- get the checker
and
Or else...
Originally Posted by bayer-z28
3 Answers...
1- get the checker
2- get the checker
and
Or else...
1- get the checker
2- get the checker
and
Or else...
