i guess i need to take oil pump off to change the timing chain..correct?
if i must take the oil pump off to get to the timing chain i guess i might as well put a new one on
Re: i guess i need to take oil pump off to change the timing chain..correct?
I put in a ported oil pump when I swapped my cam and installed a dual roller timing set. WTH, I was in there. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
MY CAR HAS 30K ON IT AND I HAVE NEVER HEARD OF A SOTCK OIL PUMP DYING WITH THIS MANY MILES ON IT. I ONLY HEAR OF THEM DYING ON CARS AROULD 5K
SO MY QUESTION IS IS IT NESSESSARY TO REMOVE OIL PUMP IN ORDER TO INSTALL A NEW TIMING CHAIN
AND WOULD U PUT A NEW OIL PUMP ON IT IF IT WERE YOU CAR.
Yes, you must remove the oil pump to get to the timing chain. And if it were my car, yes, I would replace the oil pump. But that's just me. There's obviously no need to since your's is fine. It's your call and your $$$. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
