Those who moved radiator up and verticle.... in here
Old 04-13-2007, 07:35 AM
LS1Tech Sponsor
Superman09's Avatar
Default Those who moved radiator up and vertical.... in here
Just a few questions about this set up a lot of you guys run. It seems to be great for turbo set ups clearing for a lot of extra room that is definitely needed in our cars. So if someone could list whats all involved in doing this, that would be greatly appreciated. Obviously a different radiator is needed, which seems to be a good fit without having to weld on a bunch of fittings, etc? Also what all else is needed (Coolant lines, brackets, etc)? Some detailed pictures would be nice as well. Thanks!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 04-13-2007, 07:50 AM
94blownz281's Avatar
not trying to jack this thread but i'm curious as well but using a stock style radiator if its possible to pull it forward. how are hoses long enough?
Old 04-13-2007, 07:52 AM
LS1Tech Sponsor
Superman09's Avatar
Stock won't work verticle i believe, much too tall and the fill neck is angled, its made to be mounted at the angle is on...
__________________
Old 04-13-2007, 08:03 AM
7 Second Club
ty_ty13's Avatar
i believe the consensus is a 15.5tall x 27.5 wide x 3'' thick made by griffin...
you can find it at summit....
Old 04-13-2007, 08:11 AM
LS1Tech Sponsor
Superman09's Avatar
ok thanks, what all is needed to be done to it to fit and hook everything up? Thanks!
__________________
Old 04-13-2007, 08:19 AM
LS1Tech Sponsor
Superman09's Avatar
http://store.summitracing.com/partde...5&autoview=sku
Looks like the winner! What all are you guys doing/using to mount this and hook up all the hoses, etc? Thanks!
__________________
Old 04-13-2007, 08:42 AM
bc56f100's Avatar
Heres a couple pics of mine! I also cut out the top layer of the bottom member!! That set the radiator down a little bit more!!
Old 04-13-2007, 09:10 AM
NassyVette's Avatar
Hey BC, that looks pretty nice man. What kind of fans are those? And is your kit a front mount? Just wondering if the turbo is too close to the fans? Have you experienced any heat issues?
Old 04-13-2007, 09:18 AM
bc56f100's Avatar
FLX-220 Electric Fan, Dual, 12 in. Diameter, Puller, 2,500 cfm, Black Plastic, Each $209.88 1 $209.88
GRI-1-25241-X Radiator, Universal, Crossflow, Aluminum, 27.5 in. Wide, 15.5 in. High, 3.0 in. Thick, Each $189.95 1 $189.95
Preciate it!! Theres the fans and radiator I got from Summit!! Yea its a front mount and the turbo is a good bit away from the fans! I have a heat sheild on the hot side that is pretty close but nowhere near touching!! Im in the middle of putting a new stand alone system in it so cant give much more info right now but before the fans didnt get really hot much!! Those fans pull air like a ****!! Hell they'l hold a peice of cardboard on the front mount when you turn them on!!! Heres a shot of the turbo!
Old 04-13-2007, 09:34 AM
T/A KID's Avatar
bc56f100 Thank you so much for the info and pics
SO by the looks of it everything sits in there just perfect, how are the temps?? I want to do this to my daily driver how do you think it will cool???
I wonder if Griffin could add a 6an bung and a Coolant sensor spot on the passenger side of the rad???
Old 04-13-2007, 09:44 AM
bc56f100's Avatar
No prob.!!
Yea they should be able to do that!! I had a cooling problem but that was cause my lower stainless hose was leaking out my coolant! Ha! But when I got it to stop it kept the temps down real good!! And at idle the air temp comming out of the charge pipe from the intercooler was a crap load cooler than the temp outside!!! So I would'nt think you would have a problem with them at all!!
Old 04-13-2007, 09:53 AM
T/A KID's Avatar
How are you stabilizing the radiator now?? most guys have a Bar running across with it bolted in. I can't tell how you have yours??
Thanks for the help
Old 04-13-2007, 09:56 AM
BC where did all your wires and harness's go? looks clean....
Old 04-13-2007, 10:11 AM
bc56f100's Avatar
I didnt want to see anything so I made some brackets to slide on the sides of the radiator and bolt to the front support! The first pick is the two brackets, the second is the foam used inside the channel and the third is hard to see but its on there!! I hate wires so there all hidden everywhere!! LOL Preciate!!
Old 04-13-2007, 10:59 AM
PurEvl's Avatar
heres how slowhawk did mine
Attached Thumbnails Those who moved radiator up and verticle.... in here-408b.jpg   Those who moved radiator up and verticle.... in here-408fl3.jpg
Old 04-13-2007, 11:02 AM
bc56f100's Avatar
I like that....looks real clean!!!
Old 04-13-2007, 11:23 AM
PurEvl's Avatar
this was his guinie pig prototype car....you should see the **** he does now LOL I need an update
Old 04-13-2007, 11:35 AM
bc56f100's Avatar
LOL I hear ya!!!
Old 04-13-2007, 01:15 PM
7 Second Club
ty_ty13's Avatar
is that a dual radiator?
what size is the non oem?
Old 04-13-2007, 01:37 PM
PurEvl's Avatar
stock radiator, the other thing is 4" intercooler
Quick Reply: Those who moved radiator up and verticle.... in here
