Trans mount
Old 04-13-2007, 09:14 PM
nova65ss's Avatar
Default Trans mount
Looking for one a little shorter for a 4l60e. Everything I've found is 1.9" or so. Any ideas or do I just lower the mount down a liitle with shims? Thanks,
Jimmy
Old 04-13-2007, 09:57 PM
Jhankinson's Avatar
I shimmed mine with some i machined out of aluminum. Makes it alot easier than modding a xmember to make it taller.
Old 04-14-2007, 08:25 AM
nova65ss's Avatar
Thanks I'll just drop the x member figured that would be the answer just thought I would throw it out there.
Jimmy
Old 04-15-2007, 02:56 PM
nova65ss's Avatar
Went out there today and shimming it down is not a possibility. I have a TCI 4 link that came with subframe connectors and the x member sits on top of the sfc's. Shimming it down is not an option, I have searched all over the web for thinner trans mounts and only find 1.9" tall so far. I need to be around an 1- 1 1/4 if possible. Any help would be great.
Jimmy
Old 04-15-2007, 05:20 PM
patgizz's Avatar
looking for a solid one? you could get some 1x1 or 1.25x1.25 tube and make it yourself.
Old 04-15-2007, 05:43 PM
nova65ss's Avatar
Will there be a problem with a solid mount? I have never seen someone solid mount a trans they have always had some sort of bushing. Thanks,
Quick Reply: Trans mount
