Take a look at my cam bearing please.
Old 04-13-2007, 10:03 PM
seawolf18's Avatar
Default Take a look at my cam bearing please.
I finally got the heads and cam out of my car tonight. Looking at the front cam bearing, I found the following in the pics below. Also, when I feel around the bearing there is a rough spot at the 6 o'clock posistion. Is the bearing shot? Car has 71K miles on it. Thanks.
Old 04-14-2007, 05:20 AM
mushroom281's Avatar
i'm curious too a friends bearings looked like that when we swapped his cam too
anyone??
Old 04-14-2007, 07:39 AM
LS1MCSS's Avatar
If it was smooth, I would say run it but since you have a rough spot it would be a good idea to have them changed. My engine only has 62K on it and my cam bearings looked a lot better than that. Looks like you get to pull the engine unless there is a LOT of room in front of it.
Old 04-14-2007, 09:36 AM
seawolf18's Avatar
Thats just great. . The engine had good oil pressure before I tore it down. I just hope I didn't screw it up pulling the cam out.
Old 04-14-2007, 03:06 PM
LS1MCSS's Avatar
If it had good oil pressure, you might be safe to run it like it is. It's just one of those decissions you have to make. Do I run it like this or spend a lot more money on it??
Old 04-14-2007, 05:07 PM
seawolf18's Avatar
Well, its pull it and rebuild it, or drive it, blow it up, and then rebuild it. I going to have a guy come over today and have a look at it and see what he thinks. In the end I think I will probably roll the dice.
