Good nitrous rings?
Good nitrous rings?
Ok, plan on doing a stock bottom end rebuild this summer with a cam and wanna continue to spray a 125 shot on it. This is just a cheap rebuild while I save for the forged 383 with a D1 I wanna get later on down the road. Just wondering if this is a good set of nitrous rings or if someone has some better rings for a stock piston.
http://store.summitracing.com/partde...5&autoview=sku
Get the Mahle stock LT1 rings
Originally Posted by vtec
i used a set of oem type mahle rings. they will all need to be filed if your looking to hit it with nitrous. actually, for a 125 shot you may not need to file them at all.
Note that the rings you link to are not the right size for a stock piston.
The Mahle stock OEM replacement ring package (plasma-moly top ring) is part number 2M4626-STD
link to photo of rings---and Mahle OEM bearings.
http://www.ellweinengines.com/Ellwei...ndBearings.jpg
That is also the Hastings part number which is another good ring set.
The Mahle ring set can take a ton of abuse and at least a 150hp shot of nitrous.
hth Karl Ellwein
Originally Posted by Tony Shepherd
Correctamundo.
