5.3 head Compression???
Re: 5.3 head Compression???
Probably nothing. They valves are smaller so you have to change them. 1 point of compression is worth about 20 HP. But it will all equal out to the same if not a loss of HP. Best bet is to get them ported and some new valves to use them to their full potential.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by TooSlowFiveOh:
<strong>Does anyone know what the typical gain is from just bolting on a stock 5.3??</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I think stock 5.3's have 1.84 inch intake valves. This is too small to make good power. You'll want to get a 2.02 intake valve and good valve job at the very least.
If you have a set of 5.3's and for all the work involved think about getting a set of ported heads from >>>>>>>>>>>>> there.
TEA has excellent heads. TEA Stage 1's are very affordable and will make good power. Also the Stage 2's are nicely priced. If your going to swap heads, get a good gain out of it.
www.totalengineairflow.com
