Small Block & Big Block Chevy Specific - BBC Clearance Question
evojuiced
04-14-2007, 09:14 PM
Can someone measure the distance between the frame rail and the exhaust port on their 454 4th gen swap.
also from the valve cover to the shock tower.
How close does the steering shaft come to the head?
smokin2002
04-15-2007, 08:34 AM
itll fit. just need custom header work for the steering knuckle. you can set a complete motor less carb dist cap and headers straight thru the hood
evojuiced
04-15-2007, 01:25 PM
i know it will fit, i'm trying to see if their is any way to make a set of forward facing turbo headers that will clear the shock towers.
ulakovic22
04-15-2007, 02:04 PM
You can do it but the turbo's will have to be mounted a little low. You can't come over the top like with an SBC.
evojuiced
04-15-2007, 02:09 PM
it will be running a large singe in the front bumper area.
ulakovic22
04-16-2007, 09:46 AM
Front and center or off to one side with an intercooler or what? Doesn't sound like it will be a problem then.
evojuiced
04-16-2007, 10:17 AM
front and center with the IC in the cab, Only problem is i also have to fit a 5" DP
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
