9inch HELP!!!!!!!
Old 04-14-2007, 09:52 PM
blue83z's Avatar
Default 9inch HELP!!!!!!!
Hey guys.Installing a 9inch ford Moser in a 98 trans am.Having alot of trouble fitting the BMR torque-arm to the housing mount.Anyone else have these problems?What other torque arms are you all useing?Any help much appreciated!Thanks,Lyle
Old 04-14-2007, 10:22 PM
nahasapeemapetalon's Avatar
Is the rear end jacked up? If so try holding the car up elsewhere and letting the rear hang down, thats what ive done to get it in easy.
Old 04-14-2007, 10:34 PM
blue83z's Avatar
Yes we tried that.There are big rads that needed to be ground off and we are useing the second set of holes in the torque arm.The bolts go thru the top but not the bottom.the car is on jack stands with the rearend on 2 jacks.Thanks
Old 04-15-2007, 12:01 PM
EPP
EPP's Avatar
Just grind off what you have to. We don't normally have any problems fitting torque arms on the Moser 9 inch rears, but occasionally it does have a slight interference. Bob
Old 04-15-2007, 02:07 PM
blue83z's Avatar
Thats looks like what we have to do.Thanks Bob.
Old 04-15-2007, 06:14 PM
blue83z's Avatar
Now that the torque arm fits on the moser housing,it looks like the rearend sits 1.5 inches back too far with one control arm on.the other control arm is 1.5 inches away from hole.How can this be?Is the torque arm too long?why?It fit on the old stock rearend no problem.Moser housing is supposed to be direct replacement.The control arms are also BMR.Has anyone else ran into this problem?
Old 04-16-2007, 02:05 AM
35th SS's Avatar
running a spohn t/a via the crossmember on the m6 and just did a swap on my 35th with a random tech t/a.no problems here.
Old 04-16-2007, 05:34 AM
EPP
EPP's Avatar
Question
Can you post some pictures? The Moser 9 inch is indeed designed to be a direct swap. Bob
Old 04-16-2007, 08:00 AM
blue83z's Avatar
I will post some pics as soon as I can.Thanks guys!
Old 04-20-2007, 11:41 PM
blue83z's Avatar
Had to loosen torque arm up front.Slid forward.Now its good.Thanks for help guys.Lyle
Old 04-21-2007, 04:54 AM
EPP
EPP's Avatar
I'm glad to see you got it moved forward. Bob
