4 PCM codes. Please help! Thanks
Alright, got 4 codes in my pcm. Following codes: 96 Z28
1351 (think it was random misfire) But this is major!
1441 (Auxilary Emissions for MAP sensor I think)
1641 (same as 1441 I think)
1642 (" ")
Well. Got a new opti, new MAP sensor, new ignition control module, new MSD coil, new wireset, new fuel pump, fuel pressure regulator and a fuel pressure guage. Dont know what is causing this mis unless the damn opti went out that fast. I got some new injectors but tuning so I can run them but cant tune til I fix the misfire. Also new NGKTR55IX plugs, gapped @ 35. Got all that stuff on here and its really bad in first gear and @ 60-100mph. cant get it over 110 mph. If anyone knows what these codes are and what to look for or how to fix this prob, please help. Thanks for any input!
1642 (" ")
P1351 Ignition Control (IC) circuit high voltage (open circuit)
P1441 Evaporative Emissions (EVAP) system flow during non-purge
P1641 Fan Control (FC) relay 1 control circuit
P1642 Fan Control (FC) relay 2 and 3 control circuit
