Head Performance
Old 04-15-2007, 08:31 AM
KAOS's Avatar
Default Head Performance
which heads perform better l92 or the ls7's? i know that the l92s have great flow numbers and make good power but ive yet to see a whole lot of results out of a set of ported ls7 heads... so any info would be great
Old 04-15-2007, 11:52 AM
Ellwood's Avatar
I would say the LS7s. The biggest draw to the L92s is the bang for the buck. Bare L92s are ~$200 where the LS7s are what $800? $900?
Old 04-15-2007, 08:18 PM
KAOS's Avatar
so stock ls7s are that much more? why i wonder? and that is bare?
Old 04-17-2007, 07:27 PM
Ellwood's Avatar
Production capacity would be my bet. The LS7s are for Vettes, and the L92s are for trucks. Lots more trucks out there.
There are some interesting options in the GM Perf Parts catalog, like CNC ported LS7 heads...
Old 04-18-2007, 06:46 AM
Stang's Bane's Avatar
The standard LS7 head is already CNC ported. Flows around 360-370 cfm at .600. They also have a better chamber than the L92's. However they are not cheap. they do offer a as cast head for a little cheaper, but to be quite honest with you, I really don't think you can beat the factory CNC port for a vehicle that will be on the street any.
Old 04-18-2007, 10:27 AM
CamaroRick's Avatar
whats the ls7 head minimum bore size
Old 04-18-2007, 10:29 AM
4.10 is the bare minimum as they sit, unless you get creative with placement.
Old 04-19-2007, 03:30 PM
darrensls1's Avatar
ETP makes LS7 heads for a 4.0 bore. These work great on 400+ ci motors with a LS7 intake and a 90MM throttlebody.
Old 04-19-2007, 08:03 PM
KAOS's Avatar
what is the cost?
Old 04-19-2007, 10:50 PM
darrensls1's Avatar
what is the cost?
About $3,200 for the heads. But the good news is the LS7 intake is only about $300 if I remember right so that helps offset the cost a little. It's not the most cost effective setup but it should produce fantastic results with a well matched cam.
Old 04-20-2007, 08:09 AM
KAOS's Avatar
im assuming this is for the et ls7's right? what is the cost for gm ls7's? how hard is it to do a 4.1 bore? will a stock iron block do it? or ls2 block or l92?
Old 04-20-2007, 11:00 AM
darrensls1's Avatar
Yes sir.
I have no idea. Maybe someone else can chime in on this.
No. When I was researching shortblocks I found out that the 383, 402 (ls2), 408 (iron LQ9) and 416 (L92) could not use the GM LS7 heads due to thier bore. This is where L92 or ETP LS7 heads are usually used to accomodate the smaller bore while still flowing great and making alot of HP.
If money is a concern then you can't beat the L92 heads for bang for the buck. If money is not a deciding factor then IMO the ETP LS7 heads with a LS7 intake is the cream of the crop (so to speak).
Old 04-20-2007, 11:41 AM
GM LS7 castings are ~$1800 for the CNC ported castings and ~$2500 for the assembled heads. Remember, on the assembled heads, the factory TI valves have issues, and the springs are only good up to .600. So make you choices wisely..
FWIW The factory LS7 intake is by far the best composite intake available, however, to keep up with a 454 ci motor, you may need some more...... Adjust cost accordingly.
What would this motor be going in? What do you want out of it? How much money do you want to spend?
Old 04-23-2007, 03:23 PM
john_sblendorio's Avatar
Suppose the ported L92's flowed almost as well as the LS7's (I think some are almost as good), do you think the LS7 intake will produce more power in a FI application (SC or TT)?
Old 04-23-2007, 03:27 PM
John, the power potential difference between the L92's and the LS7's is more than just the amount they will flow. From what I can gather, the L92 just doesn't have the meat in it to really lay down the numbers to compete with the LS7 head.
I honestly believe we have just seen the tip of the iceberg on these heads. (both of them)
Old 04-23-2007, 03:31 PM
Once you step into FI, that changes everything. If I were going to go that route on either one, I would go with the ET LS7 stuff and a carb style intake. I would go with the ET heads because of the thicker deck, and the carb intake because it will not blow up. I know there have only been a few, but I value my car too much to risk it. This is just my opinion..
Old 04-23-2007, 05:21 PM
gun5l1ng3r's Avatar
What do you mean by the L92's not having the meat on them?
Do you mean not enough physical aluminum to do a good port?
And do you think we have seen the end of the cathedral ports in favor of the square ports?
Old 04-24-2007, 08:33 AM
Right on the second one. This was a quote by a head porter that I consider one of the best
The flow numbers are definitely important, but not #1 unless you have a 400 inch SBC with double humps.
The better the head, the less the flow numbers matter for overall performance. There are guys that have SB2 heads they claim flow 450+CFM. If they flow that much, good for them. The heads on the car leading the most laps at Phoenix on saturday don't flow anywhere near 450, but they are as big volume-wise as the 450 CFM heads. The fast running heads have proper geometry with a properly shaped flow curve. What I mean by properly shaped flow curve isn't internet info, but I can say the flow curve will look a certain way when the port geometry is right; along with the valvejob. If it could be explained on the internet in it's entirety anyone could do race-winning heads.
I have seen two identical heads (CNC program) make quite different power because of the valvejob only. The heads that make more power would appear completely inferior to most people because they don't have a "lot of area under the curve".
Extremely poor heads like a pontiac need raw flow numbers because the port and chamber are so horrendous they will never have enough intertia to make power. I think it takes a good guy to make a head like that run.
Pro Stock on the extreme opposite side, will be almost entirely geometry specific to making power. There are things on these heads guys do that hurt flow tremendously that picks up a bunch of power. If a Pro Stock engine builder bought heads the way most people do on the internet they would never qualify, I guarantee it.
There was a lot more, but you get the idea.
As far as the last question. Within the next couple of years, I believe GM will quit producing the cathedral port heads for performance applications. Hell, after this year even, if the LS3 is what I think it is...
