A4 WOT shift point settings
Old 04-15-2007, 09:42 AM
billiardcue's Avatar
Default A4 WOT shift point settings
WOT settings - do you use MPH or RPM as the guiding parameter for the 1-2 and 2-3 shift points?
I've been using RPM, my 1-2 shift is always right on the money but the 2-3 moves around.
Old 04-15-2007, 10:59 AM
LS1Tech Sponsor
performabuilt's Avatar
I am not a tuner , But from my reading its my understanding its a function of both and each are dependant on the other
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 04-15-2007, 11:06 AM
FLT
FLT's Avatar
As mentioned above both mph and rpm parameters need to be meet for the trans to shift as programed. The 2-3 shift always seems to be the harder of the two to get dialed in because of stall speeds and what not. Unless the 3-4 clutch is starting to fail. You might want to try starting a thread in the tuning section if you have not already done so. Good luck, Vince.
Old 04-15-2007, 11:36 AM
I'm with you on the two parameters needing to be met.
I've always set the MPH lower so the shift would occur at the RPM setting.
1-2 shifts where the RPMs are set, 3-4 doesn't always, it is usually higher than my RPM setting.
3800 Vigilante converter, RPM level V trans just refreshed.
It was suggested that I set the parameters the other way around for more consistancy.
