question
Old 04-15-2007, 02:27 PM
cptncdy's Avatar
Default question
i got my tune on saturday from HPE, and i am very happy with it. the car seems a lot stronger. the only problem is that on the way home the car started shifting out of 1st gear really hard even when i would barley give it gas. once i got home i put in in park and when i put it back in drive it jerked forward really hard. later on i went for a drive and it drove normal. i thought it might have been a bad u-joint so we changed out the front one. it drove fine for a couple of hours but then started doing it again. i know that it probably doesnt have anything to do with the tune, but i was wondering if anybody might have an idea as to what is wrong.
Old 04-15-2007, 10:18 PM
cptncdy's Avatar
well, what ever the problem is, it just caused my driveshaft to snap...
Old 04-15-2007, 10:42 PM
LS1Tech Sponsor
performabuilt's Avatar
Check for codes and did you notice if the converer was locking up and when Sound like Very high line presure. But since intermitant really sounds like code 1870 is the SES light on.?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 04-15-2007, 10:45 PM
cptncdy's Avatar
no the SES light isnt on. what is code 1870?
Old 04-15-2007, 10:47 PM
LS1Tech Sponsor
Its a code that sets when the converter is comanded to lock and either dosent or slips excessivly this will cause max line and very hard shifts even at light throttle
__________________
Call 888-744-6542
Old 04-15-2007, 10:55 PM
cptncdy's Avatar
what do you have to do to fix the problem?
Old 04-15-2007, 11:10 PM
LS1Tech Sponsor
Well first determine if that what it is, Hook up a scanner and watch the data stream and watch fo lockup then look at slip percentage . also note force motor current then post back up and we can go from there .
__________________
Call 888-744-6542
Old 04-15-2007, 11:25 PM
cptncdy's Avatar
i dont have access to a scanner, but if that is what it is then what will it need to get fixed? ?(im just trying to find out how much money im looking at)
Old 04-16-2007, 09:15 AM
LS1Tech Sponsor
You cant just thow parts at it and hope You going to have to get it scanned most trans shops have a scanner
__________________
Call 888-744-6542
Old 04-16-2007, 09:41 AM
cptncdy's Avatar
but like i said, if that is the case then what will have to be done in order to fix the problem? im not just going to fix something unless it is broke. what causes this to happen?
Old 04-16-2007, 09:52 AM
LS1Tech Sponsor
Possibly a bad or blocked screen on a PWM solenoid, A worn TCC regulator valve in the valve body . Though honestly since this started right after a tune , I would really look back at that , It may be coincidence but allways a good idea to look at anything that was alterned just before this occurred, Have them if they changed any return the tune back to stock first,
__________________
Call 888-744-6542
Old 04-16-2007, 02:06 PM
Chuck@'s Avatar
I always raise the line pressure just a tad, to give you that feel of a shift kit. And the pressure I set it to is the same pressure I've been using in A4's for years now... Never had one do this. So that is very strange. If you want to bring it by we certainly can hook the scanner up to it and try to see what's going on.
Chuck @ HPE
Old 04-16-2007, 04:22 PM
cptncdy's Avatar
sent u a pm
