BMR springs 2" drop not 1"
I just received my BMR springs last week and installed the rears Friday, They were suppose to be 1" drop (what I wanted) when I measured the wheel well lip it has droped it 2" in the rear? I figure they will settle a bit more. Has any one used their springs and did you end up with 1" or ?. didn't install the fronts because I don't want to go through the work to just take them off if they are too low . Thanks.
Install the fronts before you do anything else. How can you say that BMR springs lower the car 2" when you only have 1/2 the kit put on. My car lowered 1 1/4" once the springs settled
What I said was it lowered the rear 2", There is hardly any diff between front and rear height with the BMR rears and stock front springs, My car measured 2" higher in the rear when I started. If the front was highter than the rear them I could understand the weight shift issue. If it was only 1.5" or so I could understand BUT! 2" seems a bit off. NOt flaming BMR I have other equipment on my car of BMR's and like it! just wondering if any one else has the same issue.
