LS7 valve spring specs
Old 04-16-2007, 02:30 AM
PREDATOR-Z's Avatar
Default LS7 valve spring specs
Hello,
I've been getting some inqiries about LS7 springs to fit (or not) certain aftermarket cam lobes requirements.
These are the LS7 spring pressure specs to give you an idea of whether they would be capable of handling the cam.
As we know it is not only the lift that affects that decision but more precisely the seat/open pressure capability of the spring.
Valve Springs - Free Length
58.8 mm
2.313 in
Valve Springs - Installed Height
49.75 mm
1.959 in
Valve Springs - Load - Closed
450 N at 49.75 mm
101 lb at 1.96 in
Valve Springs - Load - Open
1380 N at 34.75 mm
310 lb at 1.37 in
Coilbind is 1.085 in
Old 04-16-2007, 07:32 AM
oange ss's Avatar
are they beehive type ?
Old 04-16-2007, 10:20 AM
PREDATOR-Z's Avatar
Yes ..
Old 04-16-2007, 11:58 AM
vettenuts's Avatar
The early LS7's were dropping springs, any news of this still happening?
Quick Reply: LS7 valve spring specs
