help with milling heads , pushrod compression
Old 04-16-2007, 01:13 PM
Bader-X's Avatar
Default help with milling heads , pushrod compression
Hi
I calculated that a .20 mill of 806 heads is about 5 mm taken off the bottom head surface wich is about half a centemeter ... is this correct and what will the chamber cc be after milling? (and how about .15-.10-.25 while your at it )
I have a 98 with a tr224 with 7.400 with that much of milling what will the compression be (with stock gaskets) and will I have to change to a shorter pushrod (7.350 or 7.375) just guess and help me I know a pushrod lenth checker but that`s not a practical method here (the only available are 7.400 and when the engine is opened can`t wait for more than a week for this to come).
thanks and if you provide the formulas and/or examples for other users help in searches then thanks even more.
Old 04-16-2007, 01:18 PM
brad8266's Avatar
.020 mill you knock off about 3-4 cc's of chamber volume, which is 60-61cc on a 806 head IIRC.
Old 04-16-2007, 01:54 PM
GR33N GoblinM6's Avatar
i thought 806 heads were 69cc's to start... not 64cc to start...
and i thought the 241 heads were 67cc's... and you mill .007 to take off 1cc.. so .021 to get to 64cc's on a 241 head...
is this not right?
Old 04-16-2007, 02:04 PM
brad8266's Avatar
That may be true, im not sure, I do know they are 5.3L heads and my 5.3's were 64cc's.
Old 04-16-2007, 02:16 PM
806's are 5.3 heads? ive never seen a or head of a 5.3 head having casting # 806.. as far as i know the 806 heads were only used on 98 Fbody's and have a 69cc chamber.. the 853's were on the 99-00 cars.. and the 01-02 cars got the 241 67cc heads..
only head i know of with stock 64cc's is the 243 LS6 heads...
anyone else please confirm or set this straight?
Old 04-16-2007, 03:06 PM
Phil'sC5vette's Avatar
On my stock LS1 heads and my TR224, the 7.40 seemed to work fine.
When I had the 228R installed under AFR 205s milled -0.020, I should have changed to 7.425 rod lengths. I did picked up some valve train noise between the cams.
Old 04-16-2007, 06:03 PM
brad8266's Avatar
yeah just ignore me, im really confused today.
Old 04-16-2007, 11:19 PM
Bader-X's Avatar
yeah the 806 are 98 ls1 heads (wich is on my 98 car) 67.8 or 68 cc chambers as I`ve read here .... damn .20 mill and it`ll knock off only 3-4 cc? that`ll make it 64 only as a stock ls6...
1 inche is about 2.5 cm = 25 mm , .20 inche =5 mm ...
this is how I calculated (could be wrong) so is it a .020 something else other than inches?
I thought that since with stock afr and stock cam it`s 7.400with an aftermarket cam might go a little longer ..... but milled heads and aftermarket cam and longer than 7.400?
thanks for the replyies still waiting for more light on the subject.
Old 04-17-2007, 09:24 AM
do it this way... for every .007 you take off about 1cc ... so .028 off will take you down 4cc's to 63.8cc if thats what you want...
