Spark plug tricks?
Spark plug tricks?
have a misfire after storage and decided to go ahead and change the plugs and see if that fixes it, but realized how much of a major pain in the *** it is to get the plugs out of the passenger side.....anyone know of any tricks or what is necessary to get them out?
Originally Posted by gollum
There is no need to remove coil packs.
Use 20" long 3/8 extension and universal on the rear drivers side.
Remove#8 from underneth car.
the only one that gives me problem is the dreaded #8 plug. buy a SHORT, STUBBY ratchet and get it from underneath. works like a charm no extensions or nuttin. p.s. sportin some dynomax LT's here.
I can change all my plugs from up top in 15 min's no air pump or EGR in the way with pacesetter lt! All i have is 3 bolts holding on each coil pack "Fu** the back bolts" I use a spark pug socket with a 3/8's swivel taped to it with electric tap to hold them together and also around the swivel part to stiffen it up and use it with a ratchet and that's about it! Ii makes it so easy!
