Which fuse block and relay box are you using?
Just curious to get some ideas here.
I've seen people using the Painless 7-circuit fuse block for wiring...but no clue about relays.
I need to use at least 5 relays in my setup (fans/cooling/fuelpump/clutch safety/IGN), and I wanted to just jack a relay box from a 99+ GM pickup, but I was curious if anyone sells a "relay bar" or something that was watherproof and could be used under the hood to keep it all out of the way and inline between the battery and cab?
If anyone has suggestions on fuse bars I can get at the local parts store, I didn't see anything and I'm interested...
I bit the bullet and went with an American Autowire fuse/relay/terminal block and harness kit. I've done three cars already with their products and I really like they way the block terminal connections work. The product looks as good as it works.
That's good news, I've been hearing about AAW kits from a lot of people lately, and I like how they don't use a through-the-firewall bulkhead when installed, which makes it easier to shave the firewall and put things whereever you want. What do they offer for relays in their kits? i.e. how many relays, and is it enough for the LS1?
I really liked keeping things modular, which is why I was asking about the relay situation. I kinda want to put them somewhere nice and sealed....
sawzall wielding director
No , they are all individually wired. I just tied them together outside the box with solder and shrink tube. It isn`t the most elegant solution, but it was cheap, easy, and works well for my daily driver. Its no show car, it just needs to be fast and reliable.
The fuse box is mounted just to the right of the computer in this picture, as you can see theres a lot of wires going in/out of it, but there is actually still some room left for wires to enter/exit. I used the trucks power distribution block (red box on the alt bracket) to provide power for all the relays.
I used 3 Autozone fuse blocks and 7 of Bosch relays, with the relays mounted to an aluminum bar. In retrospects, I should have gone to a junkyard and gotten a factory style fuse/relay block. My wiring is basically the same as the schematic in the stickies, except I ran switched power to terminal 85 of the left & right fan relays instead of battery power. I don't want fans coming on by surprise with the engine off.
There was a thread somewhere around here (if searched worked ide find it for ya) where a guy took two stock f-body fuse blocks, and combined/re-worked them to make one really nice, complete fuse block. It looked really neat and tidy when he was done, and he had all the circuits that you'd need.
Im just using the stock f-body fuse blocks without modification. Lets all the engine harness parts just plug and play into it. And all I really had to do to make it all work was run a power wire to it, a switched ignition wire, and ground it. And viola, the relay boxes basically worked just as they did in the 99.
J.
J.
The power feed for box E comes via box C so you have to re-work the feeds and the routing of the power lines from fuses around but I swear to you its very self explanatory once you are looking at the boxes. Anyways thats what i did and it looks neat and tidy and works fine. All said and done I have two fused circuits and three spare relays left over
I see that you are looking for a fuse block which has removednon-sponsor link[/COLOR] features.I would suggest that it would be nice if it would have a soldered bar on your hood to keep it from getting to near the battery.
Last edited by G-Body; 04-17-2007 at 01:47 PM. Reason: Removal off non-sponsor link
Originally Posted by 350SS
Who makes that setup?
They have a LOT of stuff, looks like a great place to shop. Can't beat that price, I think I'm gonna go for it.
Good info in this thread!
