796 Rwhp 720 Rwtq 347cid C5 Auto F1r
Old 04-16-2007, 10:15 PM
SLED28's Avatar
Default 796 Rwhp 720 Rwtq 347cid C5 Auto F1r
I think we all know EB on here... Well finally the snow melted a bit up here in the Great White North and he finally got it thawed and out to the local dynojet...
796rwhp @ 6200
720rwtq @ 5000
Auto 4L60E Thankyou RPM Trannys!
Ran out of injectors.
Lowest boost pulley used.
347 CID with CNC'd stock Heads.
HP Tuning by Arun.
Buildup Thread:
https://ls1tech.com/forums/forced-induction/660656-progress-pics-my-cdnperf-347-f1r-combo.html
Old 04-16-2007, 10:32 PM
LS1VH's Avatar
Great effort CP , when are you taking it to the track?
cheers
Old 04-16-2007, 10:33 PM
SLED28's Avatar
Thankyou! I beleive he is going on vacation for a few weeks. Maybe I can borrow the keys for a couple passes
Old 04-16-2007, 10:39 PM
LS1VH's Avatar
Yeah he doesn't need to know that your racing it while his on vacation! lol
BTW the link to the build-up thread isn't working for me?
cheers
Old 04-16-2007, 10:45 PM
SLED28's Avatar
Sorry:
https://ls1tech.com/forums/showthread.php?t=660656
Old 04-16-2007, 11:17 PM
99Z28LS1's Avatar
sweet numbers man
Old 04-16-2007, 11:22 PM
THE_SUPRA's Avatar
kill numbers man! get some videos up asap!
Old 04-16-2007, 11:40 PM
MonkeyBoneSS's Avatar
Very nice!!!
What size injectors is he running ?
Old 04-17-2007, 12:20 AM
slowredz's Avatar
Pump gas?
Old 04-17-2007, 12:44 AM
eb02z06's Avatar
Hey guys-thanks for the props! Here is the graph, video's to come shortly:
I can't complain-almost 800 rwhp through a locked auto with 347 cubes is pretty stout-the torque is what really get's me. We had one pull and it was around 723. the car was running fairly rich in the midrange area like 10.5-10.85 then leaned out to 12.5. Then got it down to 11.5 on top and it came close to 800. I just got fed up and called it quits. Lots of little things to sort out. First off I couldn't log boost-don't know why but it wouldn't. I was told it was around 18-19psi then leveled off. I don't know power falls off at 6200-I was thinking maybe I installed the cam wrong or it's degreed wrong but if that was the case then the torque would of come in sooner as well. It's a healthy cam-10 degrees bigger than last year so it should pull right up to 6800-imagine how much power it would make then?
Injectors are maxed-130% duty cycle-even with a dual meth setup-time for a injector driver and some big injectors-these 60's are not cutting it.
Boost seems to go flat at the top when HP drops-my bov might be opening-I'll get that sorted out right away.
No signs of belt slip-still on the same belt the car was fired up on. This F1R is sick-i'm using a 4.13 pulley-I can still go down to a 3.75-this thing is sick!!!!Did I mention this cam has like well over 60 degrees of overlap-so much for boost loss-lol!!!
Dave at CDN performance built me a nice sick motor-nothing like a big blower and small cubes. I'll post more info-tomorrow-my heads going to split with all the thinking i'm going to be doing tonite!
Oh yeah-pump gas!!!
Old 04-17-2007, 01:00 AM
Jimmy P's Avatar
Great results! What size headers are you using?
Old 04-17-2007, 01:06 AM
eb02z06's Avatar
1 7/8's , Big thanks to Kooks on that one-they came through for me.
Old 04-17-2007, 01:59 AM
WHPLASH's Avatar
Holy **** Arun !!! You've got to be happy with that outcome. Big improvement over last years numbers. 9 seconds here you are !!! Awesome bro
Old 04-17-2007, 05:05 AM
EPP
EPP's Avatar
Aweseome! Vortech, you still need to change your name! Bob
Old 04-17-2007, 07:47 AM
94snake's Avatar
Damn, these F1 blowers on LSx engines make some sick power. Can't wait to see what it runs at the track
Old 04-17-2007, 08:24 AM
LS1TECH Sponsor
GeorgeR@kooks's Avatar
great nimbers. Glad we could be a help.
Old 04-17-2007, 09:06 AM
eb02z06's Avatar
Yes-it's about time Bob-any suggestions? Eb02z06? F1RPOWER?
Old 04-17-2007, 09:09 AM
eb02z06's Avatar
Are any of you guys running the 60's with 800 rwhp or more? I'm looking at those RC 75lb's-thye make them in hi-impedance. I also need to get a boost referenced regulator. My PE table is like 1.10 to like 5 grand, then 1.2 at 5-6 then 2.1 at 6grand up. Right at 6 grand you see fuel pressure go from 60psi to 40-could that be due to the pe table jump?
Old 04-17-2007, 09:36 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Let me know, I will change your name. Congrats on the numbers, what gas did you use?
Old 04-17-2007, 09:39 AM
eb02z06's Avatar
Thnaks John, I used pump gas and a can of Torco accelerator-94 octane.
Quick Reply: 796 Rwhp 720 Rwtq 347cid C5 Auto F1r
