General Maintenance & Repairs - Cleaning the MAF
View Full Version : Cleaning the MAF
5301113
04-17-2007, 02:40 PM
I saw on a show that you can clean your MAF (the little metal sensor in the MAF) with brake cleaner. Is that safe? It's a small maintenance that helps the MAF read correctly. Sometimes dirt and oil from the filter cause it not work right.Has anyone ever heard of this? Is is true or will it hurt the car more the help???? :confused:
staringback05
04-17-2007, 02:46 PM
you have to be careful using sprays, those electrodes are very fragile
2001NBMZ28
04-17-2007, 02:54 PM
Don't know about brake cleaner? Don't they sell MAF cleaner spray off the shelf? Thinking I saw it at Pep Boys.
staringback05
04-17-2007, 03:04 PM
im pretty sure they do
RPM WS6
04-17-2007, 04:01 PM
Never used brake cleaner myself, I'd be afraid to use that stuff for something so delicate.
Rubbing alcohol works well though.
taintedmeat
04-17-2007, 06:04 PM
I use CRC Electronics cleaner. They also have a special Maf cleaner spray now.
Da Swami
04-17-2007, 06:10 PM
I used the "special" CRC MAF Cleaner in the gray bottle.
It worked awesome and I TRULY saw an improvement in idle and gas mileage. Mine had 112k on it.
Demon_Speeding
04-17-2007, 06:16 PM
I've used rubbing alcohol and a Q-Tip very carefully with good results. Worked on my '86 IROC, my Z28 and a buddies '87 Grand National.
brad8266
Any auto parts store sells MAF cleaner in a spray bottle. CRC makes it.
Formula413
04-17-2007, 08:42 PM
+1 for the CRC MAF cleaner, I have read that Brake clean or Carb cleaner are too harsh. For what a MAF sensor costs it's worth it to get the right stuff.
CULATR
04-17-2007, 11:13 PM
where do i get a can of it at ? auto zone, advance auto, etc........??
LS1Formula01
04-18-2007, 02:50 PM
yes just about any local auto parts store should carry it, costs about $7 bucks/can to keep your well over $100 (replacement cost) MAF clean!
CULATR
04-18-2007, 10:59 PM
Found it today thanks !!!
staringback05
04-19-2007, 12:12 AM
+1 for the alcohol...:lol: that works on everything...:chug:
LS1Aggie09
05-16-2007, 01:50 PM
mmmm alcohol
5301113
05-16-2007, 03:59 PM
mmmm alcohol
+ 2 :jest:
