2002 T/A ws6 will not crank
I have a 2002 t/a ws6 package and the car will not crank. It has a good battery and good starter. When i turn the ignition to crank it will do nothin. Need to know if it is n the security system and if so how do i rewset it or if there is a sensor gone bad.
I dont mean the red light on the dash, I mean the actual light on the gauge cluster that reads SECURITY. If it does, try a VATS relearn:
To do that you need to turn on the key and try to start it then leave the key on for 600 seconds. Then, turn off the key and repeat 3 times.
If this doesn't do it, try your spare key. It could be the VATS system causing this, somewhat common. You can buy a VATS bypass like what people use on aftermarket alarms. Do a search for vats bypass.
Originally Posted by 2002pontiact/aws6
no loose battery cable. I can bypass starter relay and hotwire it and it turns over just fine
let me know what happens with this im having the same problem right now with no security light and if i jump the starter it works too. its gotta be something stupid withthe alarm or something
