Manual Transmission - Current master cylinder no restriction in line???
SladeX
04-17-2007, 04:51 PM
I have a new 01-02 master cylinder and just took the line off and started feeling around with a drill bit and found no restriction???
I'm sure I've pushed the drillbit by hand past the "1 inch" mark and found I would probably loose it in the line if I pushed it further.
Anyone else have any experience with the newer master cylinders? Did you have to do the drill mod?
brad8266
04-17-2007, 05:01 PM
There is another thread in here where the guy has an 01-02 and it had the restriction in it. Maybe they started not putting the restriction in the line in the last few years since then.
SladeX
04-17-2007, 05:04 PM
Here's the part number 12570277 7039-1
I called my parts supplier and he mentioned it was a GM "High Performance" MC. Anyone else hear anything on this?
