How can I re-finish Billet rims?
am going to try to re-finish a set of Billet (raw alum) rims myself. Time isn't an issue, I have lots of it.
The rims are not that bad, the inside obviously is a little worse than the face. The lip's have a little bit of pitting that you can see from one foot away.
Can I use this procedure:
Spray some sort of stripper on them that would be used to remove clearcoat, just for a cleaning.
Sand the rims down with a multi stage process of tougher grit to smoother?
The other idea is to pay someone to sand blast them and clear coat them. What do you guys think?
