trigger1
04-18-2007, 09:44 AM
I am looking for any opinions/suggestions/estimates on how my setup. I appreciate any feedback!
Last season I ran the following setup-
TR224 112lsa
stock heads
fast 90setup w/ NW TB(car was tuned with ls1 intake on it, no tuning done when I added the fast setup)
Lid
Mac Midlength headers, ORY, cutout
FRA
stock front suspension with sway bar removed
textralia clutch
9" 31 spline axles w/ 4.11 gear
CE rear shocks
UMI rod ended adj lca's
BMR adjustable torque arm mounted to trans crossmember
Some weight reduction done (no interior at all, wheels, other small items)
15x3.5 welds up front with 26x11.5 ET streets on stock 16x8 rims out back
With the previous setup I was able to go a best of 12.14@114.55 on a 1.74 sixty foot.
The new setup (Still waiting on a few things to be installed/arrive, but this will be the end result)
MS4 111lsa and appropriate valvetrain components
stock heads
Fast 90 NW 90TB
Kooks 1 7/8th LT's with X pipe and spiral flows dumped (thanks slowz28)
Lid
SSRA (thanks txcamss)
QA1 single adjustables up front with 275lb spring (thanks silverghost)
stock K member, no sway
Coan built TH400 w/ brake
Converter will flash to 4200-4400
Same rear suspension as last season
Bogarts front and rear with a 325/50/15 drag radial on the rear
4.33 gear replacing the 4.11
I also still have the 26x11.5 et streets and will probably swap back and forth between the 28" radial and the 26" et street depending on what the car does as far as MPH and hook.
The goal is to get the car into the bottom 11's, perhaps even eek out a high 10sec pass.
TR224 112lsa
stock heads
Lid
FRA
textralia clutch
CE rear shocks
stock heads
Fast 90 NW 90TB
Lid
