Do heads increase gas mileage?
Old 04-18-2007, 10:44 AM
ivanisok's Avatar
Default Do heads increase gas mileage?
I read cams decrease MPG, but will adding heads even it out by increasing it?
Thanks in advance.
Old 04-18-2007, 10:47 AM
1baddls1's Avatar
it really depends on the combo - swapping camshafts doesnt always produce that outcome (with supporting mods ofcoarse)
Old 04-18-2007, 10:52 AM
fastest94v6's Avatar
I honestly get pretty much the same gas mileage that i used to...as long as I don't put the pedal to the floor.
Old 04-18-2007, 11:17 AM
Bill Bowling's Avatar
How do you not put the pedal to the floor?
Bill
Old 04-18-2007, 11:25 AM
ShevrolayZ28's Avatar
Thanks in advance.
Lots of things can be read, whether or not they are true is another story.
Old 04-18-2007, 11:26 AM
Sigforty's Avatar
It depends on the setup. If you can increase the engine efficiency then you will see an improvement in gas mileage as well. My Z06 with a F14 cam and Dart 205s gained 3 mph on interstate cruising.
Old 04-18-2007, 01:13 PM
Bill
Hey Bill, I don't drive with the pedal to the floor 24/7....It also depends on how well your car is tuned....the theory is that, you don't have to give it a lot of acceleration to go...therefore you get better mileage...
Old 04-18-2007, 01:20 PM
Ace$nyper's Avatar
As stated before it'll all depend on the setup, yes in theory heads can gain you some milage.
