shifting issue
Old 04-18-2007, 06:01 PM
Cop Car's Avatar
Default shifting issue
ok, so my trans had been working fine, then it quit locking up.. so i bought a new lockup solenoid and replaced the 3 - 2 solenoid also. when i put everything back together, it didnt have first gear. so i took it back apart and put the 3 - 2 solenoid that was in there to start off with back in it. it still dosent have first.
when i was moving in second gear at a walking pace, i pulled it down into first and it felt like hitting the brakes. all other shifts work fine...
Old 04-20-2007, 10:29 PM
Cop Car's Avatar
so my trans is smarter than all of us it seems...
Old 04-20-2007, 10:34 PM
LS1Tech Sponsor
performabuilt's Avatar
Well if the other shifts are fine I can tell you that it sounds like the 2-4 band is always applied for some reason , Basically he second clutch oil is always being fed to the 2nd servo , This wouldnt affect other gears but with the work you did I dont see how it would cause this problem unless some trash got in there and stuck a valve .The braking affect in Man 1 is why I say the band is allways applied
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 04-21-2007, 04:46 PM
Cop Car's Avatar
would a bad 3-2 servo cause the band to always to apply like you said? when i put the new 3-2 in it didnt want to go in, and i had to kinda force the connector into the 3-2 new servo... im thinking that it might have messed up the connector, would have make it apply the 2-4 band all the time?
Old 04-21-2007, 05:10 PM
FLT
FLT's Avatar
What year is your car? Also did you replace it with exactly the same solenoid that was removed?
Old 04-21-2007, 05:45 PM
LS1Tech Sponsor
That is a posibility I didnt cosider if you put the wrong solenoid in there you may have damaged the PCM.
__________________
Call 888-744-6542
Old 04-21-2007, 05:57 PM
FLT
FLT's Avatar
Also you could have a broken 3-2 control valve spring. Just a thought. Vince
Old 04-22-2007, 12:06 AM
Cop Car's Avatar
the solonoid looked the same from the outside.. but i was told at the parts store that there are 2 diffrent solonoids that are available. i got the cheaper of the two. my car, the wiring harness and computer are 2000, the transmission is a 2001, and all the internals of the trans are 2001. it has a transgo shift kit. it just had a little difficulty plugging the sensor in. so i may have smashed where the plug goes into the sensor..tomorrow i belive im going to check the wires.. how do i check the output of the wires? i will check the spring and the piston while im in there.
i really appreciate your help guys..
Old 04-25-2007, 08:31 PM
Cop Car's Avatar
it was a blown fuse. all is fine now
Old 04-25-2007, 09:12 PM
LS1Tech Sponsor
excellent you were lucky though
__________________
Call 888-744-6542
Old 04-29-2007, 12:52 AM
Cop Car's Avatar
eh, not so sure now. after lockup, its still acting kinda like a stall. i think maybe its slipping, but when im on the throttle, it dosent seem like its slipping at all. possibly the lockup slipping?
Old 04-29-2007, 01:18 AM
LS1Tech Sponsor
Sound like a tuning issue with the converter clutch either set to duty cycle near 100 percent or mechanically eliminate PWM
__________________
Call 888-744-6542
