best speaker wire?
It's all the same. Get whatever will flow the current load you need.
I like buying from www.knukonceptz.com for my wire and RCAs. The name sounds a little shady, but their stuff is top quality and they have awesome prices.
Originally Posted by WhiteBird00
The best kind is made from conductive metal (like copper) and has insulation to keep it from shorting out.
As 95bat says, it's basically all the same - just make sure it's stranded (not solid) and get large enough gauge to handle the power you're using.
Copy & Paste Moderator
Make sure you get Oxygen-Free braided copper wire.
That will reduce (or possibly eliminate) the risk of oxidation.
Also, make sure you get the right gauge for the load.
