Rod bolt install quote?
LS1TECH Sponsor
YOu need to drop the K Member to do it right. It is not easy at all and would require an alignment on top of everything. 400.00 ain't bad for the work involved.
Have you seen this:
https://ls1tech.com/forums/generation-iii-internal-engine/675343-rod-bolt-install-write-up.html
I imagine $300 is a good price.
Originally Posted by Viper
Have you seen this:
https://ls1tech.com/forums/showthread.php?t=675343
get Katech rod bolts and I'm pretty sure you don't need to resize or align or anything like that. They are stock "blueprinted" so they are the same size and weight, just stronger.
