Street Racing & Kill Stories - B4C Police Package Car
Torque_Wrench
04-19-2007, 10:10 AM
Guys I'm not sure where to post this, so I'll post it here and a couple of diffrent places.
Hey guys....I got this guy that want's to race my Z28. He's got a B4C Police Interceptor car. It's only got am exhaust set up on it...everything else is B4C Stock. He thinks he can smoke me with his Cop Car. So....I got his VIN and ran it here at work and the only thing I see diffrent from a stock car is the B4C option.
Can someone elaborate on exactly what is the extent of the B4C option. I called my guys at GM and he told em it was nothing but a hopped up Tune in the PCM. So...exactly what does that consist of? I only know that it enables your car to Top Speed at 170mph. Other than that...I don;t know.
My car is modded all to hell, and this cat thinks he's gonna school me.....I doubt it.
g-ryde1
04-19-2007, 10:35 AM
all i can say is that if your modded up and he is stock except for an exhaust then you will royally destroy him. but ima let the B4C peeps help you out with the technical stuff. from what i gather a B4C is an option much like the SS and Z28 all option packages for the camaro. i wanna just say suspension and gearing thats about it man. of course im not a subject matter expert.
not to talk trash but your boy seems to be one of those type of seple that think a stock SS will blow the doors off a stock Z28. cant stand those type of people.
Irunelevens
04-19-2007, 10:42 AM
Powerwise it is no different than a regular Caprice... the extent of the modifications is basically the same as the Crown Vic cop cars; tougher suspension, external oil cooler, maybe a tranny-fluid cooler, etc., to make it tougher. Not faster. They will NOT do 170mph... if you see the other side of 135mph in a B4C you're a lucky guy.
Randy_W
04-19-2007, 11:10 AM
B4C is a Camaro, not a Caprice the Caprice is a 9C1. The B4C has a slightly hotter tune some years, other than that it is a Z/28 drivetrain in a plain Camaro coupe and they usually weigh a little less. They are capable of 167 mph as as shown in several tests.
ICEMAN 31
04-19-2007, 11:17 AM
like I said on your other thread he won't even be able top read your pates
Torque_Wrench
04-19-2007, 12:34 PM
Thanx man....all I can say is...Fuckin' A
bad2000z
04-19-2007, 12:43 PM
Dude you didn't hear? The B4C cars have a special "police chip" that makes the car pump out like 500hp!! The top speed is actually well over 200mph, and there's a special police afterburner button under the dash that makes the car fly. Good luck.
Torque_Wrench
04-19-2007, 12:51 PM
lol..then he's no match for my rocket enging that I used from an Army Helicopter.
g-ryde1
04-19-2007, 01:11 PM
u got VTECH in in that helochopper engine
BTW please post a vid of this ass whoopin
Torque_Wrench
04-19-2007, 02:00 PM
It's on tap for Saturday night. I'll try to video the race for you guys if I can geta camera man. But I'll for sure post up the results.
ICEMAN 31
04-19-2007, 02:03 PM
dont forget you Slow & Delerious DVD that will give you an extra 300000000 RWFWHP
Torque_Wrench
04-19-2007, 03:20 PM
lol....Slow & delirous....that's Epic!
Irunelevens
04-19-2007, 03:31 PM
I don't know why I saw "B4C" and thought "9C1." Yeah, I'm familiar with the B4C cars. Buddy of mine used to have one.
bad2000z
04-19-2007, 04:28 PM
You might wanna stop at the local cop shop to see if they have any spare "police chips" so the race will be more fair. I got a special "police chip" for my wife's Corolla, and now it runs 10's. The only downside is you have to feed the car a dozen doughnuts at least once a week or it will run like shit.
95_formula
04-19-2007, 04:31 PM
Kinda like your wife huh?
bad2000z
04-19-2007, 04:45 PM
WOW! Big diss coming from a guy that runs what...14's? Were you offended because your fat mom is a cop? or your fat daddy? fat brother? sister? Or are YOU a fat cop? Does your car have a "police chip"? I bet that's why your so cocky, your car has a "police chip" doesn't it? BTW I happen to like big women (like your mom).
95_formula
04-19-2007, 04:51 PM
Wow cool your jets, no need to start the mom jokes.......I don't think I can handle it.
bad2000z
04-19-2007, 05:18 PM
Sorry, I just cleaned the sand out of my vagina. I'm fine now.
Finite1
04-19-2007, 05:39 PM
rofl.
Finite1
04-19-2007, 05:42 PM
wikipedia says that all years after 1991 were confirmed over 145.
http://upload.wikimedia.org/wikipedia/en/8/85/FHP-Camaro.jpg
so it's an ls1 powered vehicle no doubt. You should be fine. it's just heavy duty.
Randy_W
04-19-2007, 09:24 PM
Specs on a '99 B4C
Passenger Capacity 4
Passenger Volume (cu ft) 81.9
Base Curb Weight (lb) 3471
EPA Fuel Economy Est (MPG) 17
Hwy EPA Fuel Economy Estimate (MPG) 24
Dead Weight Hitch (lb) 1000
Dead Weight Hitch-Max. Tongue Load 100
Type of Engine Gas V8
Displacement 5.7L/350
Fuel System SFI
SAE Net Horsepower 305 @ 5200
SAE Net Torque (lb ft) 335 @ 4000
Number of Forward Gears 4
Transmission Type Description Line 1 Automatic w/OD,
Transmission Type Description Line 2 Electronic
Final Drive Axle Ratio (:1) 3.23
Cold Cranking Amps @ 0ø F 525
Maximum Capacity (amps) 140
Total System Capacity (qts) 11.8
Rear suspension type line 1 Torque Arm
Front suspension type line 2 w/Coil Springs
Rear suspension type line 2 w/Coil Springs
Shock Absorber Diameter (mm) 46 Gas
Rear shock absorber diameter (mm) 36 Gas
Stabilizer Bar Diameter (in) 1.18
Rear stabilizer bar diameter (in) 0.75
Rear tire size P245/50ZR16
Spare tire size T135/60R16
Rear wheel size (in) 16 x 8.0
Spare wheel size (in) 16 x 4.0
Rear wheel type Aluminum
Spare wheel type Steel
Lock to Lock Turns 2.28
Curb to Curb 40.09
Wall to Wall 41.93
ABS System 4-Wheel
Disc Yes
Rear disc brake (Yes/No) Yes
Rotor Diam x Thickness (in) 11.8 x 1.27
Rear disc brake rotor diameter x thickness (in) 11.9 x 1.02
Capacity, Approx (gal) 16.8
Head Room (in) 37.2
Leg Room (in) 43.0
Shoulder Room (in) 57.4
Hip Room (in) 52.8
Second seat head room (in) 35.3
Second seat leg room (in) 26.8
Second seat shoulder room (in) 55.8
Second seat hip room (in) 44.4
Wheelbase (in) 101.1
Length, Overall (in) 193.5
Height, Overall (in) 51.3
Tread Width (in), Front 60.7
Rear 60.6
Min Ground Clearance (in) 4.0
Liftover Height (in) 35.1
with Rear Seat Up 12.9
with Rear Seat Down 32.8
Irunelevens
04-19-2007, 11:33 PM
All '91+ Caprices could do 145+? That's news to me, but I still wouldn't want to be in one going that fast.
tripps
04-19-2007, 11:40 PM
I guess we found the newest troll to our boards. Enjoy your stay, as it probably won't be that long.
To the OP: Please get a video! That way I could tell all my friends that I saw a cop racing a camaro bc they are that badass :devil:
Torque_Wrench
04-20-2007, 08:36 AM
lol...."cleaned the sand out of my vagina"......ha,ha,ha,...that's funny shit! You're f'n crazy!! But that's what I like in people...lol
Torque_Wrench
04-20-2007, 08:38 AM
Yeah man...I'm with you......a Caprice running 145mph....that'd be like riding a boulder at 145mph.....fuck that!
bumperdragging
04-20-2007, 08:43 AM
caprices are junk at like 60 mph arent they? feels like a brick on pizza cutters....
Finite1
04-20-2007, 09:37 AM
all police package camaros after 91 I meant, sorry.
Irunelevens
04-20-2007, 12:37 PM
Ok, that makes ALOT more sense.
sidewayz28
04-20-2007, 02:22 PM
just make sure john cena isnt driving that B4C
