Generation III Internal Engine - Collapsed LS7 lifter.
BYE RICE
04-19-2007, 11:23 AM
Just installed new heads & lifters.I noticed my oil pressure was lower than before..It wont make beyond 40-50 psi hot,& it drops below 20 at idle(closer to 15).
After about 200 miles, The engine starts to make a TAK-TAK-TAK sound..Holy shit it's loud!
It's coming from the the area right under the newly installed LS6 vally pan & behind the front cover /water pump..I pulled the #1 rocker arms & noticed very little oil splash on the #1 intake rocker.It's a Harland rebuild & the bearings inside the fulcrum are shot...As if it wasn't getting oil from the pushrod..
The oil pressure was fine before I did the head /lifter swap..Now it's not.
The oil pump is an LPE ported unit & I run Mobil 15-50 weight in accordance with what LPE told me to do.
Any ideas?
I'm at a loss & dont want to just start throwing parts at it...
Ryan02SS
04-19-2007, 02:55 PM
I would first confirm that oil is gettin to the valvetrain and go from there. Check the easy stuff first. Confirm oil hole in pushrod is free of obstruction. Fire engine up with valve cover off and confirm oil getting to the rockers would be my first move.
BYE RICE
04-19-2007, 03:01 PM
Yeah..Starting the car sans valve cover doesn't work too well with valve cover mounted coil packs..But what I will do is remove all the spark plugs,pull both covers, & spin the engine over with the starter.That's how I primed it in the first place after prior to starting it with the new lifters installed.
I'll update as I figure stuff out.
Ryan02SS
04-19-2007, 06:33 PM
That will work fine but it's a PIA to pull the plugs. Much easier to remove the coil bracket from the valvecover and lay to the side.
BYE RICE
05-01-2007, 10:09 PM
Update...
The engine runs suprisingly well on one bank of cylinders...For a few miniutes I had the only 4 cylinder 4th gen in the world...It allowed me to determine I do, in fact, have a bad #1 intake lifter.I hooked up a mechanical pressure guage using an adapter where the filter goes..The needle buzzes around between 50-70 cold & falls to 25-45 hot.
We went a step further & removed the rocker arms & pushrods on #1 & pulled them up into their retainers using a pen magnet...We hooked up the 3,5,& 7 coils & ran it.
No noise.
Bad lifter :judge:
This is a brand new(<200 miles) GM LS7 lifter,PN 12499225
WTF?
Mike94ZLT1
05-02-2007, 01:13 AM
Lol, this scares me as I am about to put a motor together using these lifters!
Rob98LS1
05-02-2007, 02:14 AM
wasn't there another thread just like this but with GMPP racing lifters that failed?
BYE RICE
05-02-2007, 05:25 AM
In all fairness...These lifters have a great track record..I feel like I'm the only guy on the planet to get a bad one.
BIG_MIKE2005
05-02-2007, 07:49 AM
I also am very interested in what actually caused this problem. I will also be goin with LS7 lifters & Harland rebuild rockers very soon.
Mike94ZLT1
05-02-2007, 08:03 PM
I have LS7 lifters and harland rebuilt rockers in an old coffee can soaking in oil in my garage, waiting for my new motor to get here :) I want em good and oily when I put them in!
BYE RICE
07-08-2007, 11:18 PM
I left this thead hanging..It wasnt a lifter.
I spun a rod bearing.
The sound was the piston hitting the quench pad.
I apologized to TSP for my "expert" diagnosis & had them build me a 383.
It all worked out..The 383 is AMAZING..It is one good running engine.
Imagine all the HP of an LS1 with torque EVERYWHERE.
The downtime enabled me to get my combination checked out & I learned alot of valuable information in regards to the heads I'm running & their initial shortcomings..(wrong CC)..That was adressed quickly by Texas Speed. Patrick G is truly a master at cam selection & is probably the biggest reason why this engine runs as well as it does.
The same can't be said about the clutch.It's shot.
Always something.But my LS7 lifters work GREAT! :judge:
BIG_MIKE2005
07-09-2007, 07:28 AM
cool. Thanks for the update
