Help with a new setup!
I'm torn between the ms3, ms4, tr trak cam, or am open to other suggesstions. Here is my current setup and I can change out whatever I need to. Opinions please!
Current Mods:
346 c.i. LS1 – Stock bottom end
Cylinder Head Specialties Stage 2 Heads – These are being re-done
(REV 2.02 intake, 1.57 exhaust valves, & custom competition dual valve springs)
Comp Cam .222/.222 (Dur.) .566/.566(Lift) 112 (LSA) – changing to whatever
Comp Cam 7.4 Chromeoly Pushrods
Rollmaster Dual Roll Timing Chain
Yella Terra 1.7 Roller Rockers
Hypertech 160' Thermostat
Taylor 10 m.m. Plug Wires
NGK TR6 Spark Plugs
Racetronix 42lb./hr. Fuel Injectors – changing to whatever
Walbro 255lr./hr. In-Tank Fuel Pump
LS1 Edit
Fast 90 & Nick Williams 90 TB
SLP Mass Air Flow Sensor
SLP Flo-Pac
Jet Hot Coated Headers
" " Y-Pipe
" " Exhaust
" " McCord Electric Race Ready Cut-Out
Stage IV Speed Inc. Max Evil A4 Transmission
TCI 3500 Stall Converter – changing to whatever
B&M Supercooler
3.73 GM Motive Gears
TA Performance Rear End Girdle
Additional upcoming mods are: Meziere electric water pump, ls7 lifters, ASP UD pulley, etc.
Current Mods:
NGK TR6 Spark Plugs
LS1 Edit
SLP Flo-Pac
" " Y-Pipe
" " Exhaust
B&M Supercooler
