Need Spark Plug Reccomendation
Old 04-19-2007, 01:12 PM
1QWKT/A's Avatar
Default Need Spark Plug Reccomendation
I have a 383, about 11.5:1 cr with the AI 190cc Head Package and a .236 .242 116 lsa cam with all bolt ons. We've had it tuned, but not on a dyno yet, going to get an Edge racing converter. I fouled out my NGK TR55 Iridiums b/c it's running rich. Should I go up a heat range? What kind of plugs have you guys successfully ran on similar setups?
Old 04-19-2007, 01:52 PM
rbrcka's Avatar
I would recommend a regular copper NGK TR55 with around .045 - .050 gap. I have never been a big fan of the Iridiums since the tip is so small they tend to blow out easier. I would get the tune sorted out though instead of trying to fix it with a hotter plug. Because even if it was rich at idle or part throttle you could burn it up under wot.
Old 04-19-2007, 06:24 PM
1QWKT/A's Avatar
Yea, I am def. going to get it retuned before I start it with the new plugs. Those just seemed to foul out easily so I thought I needed a change. Thanks for the help!
Old 04-19-2007, 07:51 PM
96capricemgr's Avatar
Honestly I found the TR55s to be a little too hot for my car. I would consider Autolite 104 or NGK TR6.
Old 04-19-2007, 11:21 PM
1QWKT/A's Avatar
Thanks and also, What gap are you running? I have been reccomended .035 and .045
Old 04-20-2007, 08:29 AM
1QWKT/A's Avatar
TTT, anyone know for sure what gap would be best? .045?
Old 04-20-2007, 01:02 PM
3pnt4maro's Avatar
im running tr55's with a .045
Old 04-20-2007, 04:22 PM
speed_demon24's Avatar
I'm running autolite 104's gapped at .040 in my car.
Quick Reply: Need Spark Plug Reccomendation
