solid motor monuts?
solid motor monuts?
i got a set of madman solid motor mounts for my 94 z i am also doing long tubes at the same time has anyone used these solid motor mounts? they came today with no directions i know its just a motor mount but anyone with some info please help!!!
It's pretty straight forward. Just take whatever off that's stopping you from getting to the mounts. Headers need to come off to make your life easier.. luckily your doing that anyways.
It's just two pieces of steel that look like the motormounts minus rubber. Bolt them to their respected places, and then put the bolt through the mounts to hinge them together. They came with no directions because none are needed.
Will they have a bolt threw the middle it seems to me like they wouldnt.
Uh... what? Not sure what you're asking, or maybe even saying, but every SBC motor mount I've seen has a bolt going through the two pieces holding them together.
___
\___/
Meh, I'm drunk and pissed off, I hope that drawing makes sense Bottom is what bolts to the motor, top is the frame portions. When they come together, the bolt (which is []=====) goes through joining them.
Formula350, there is no middle bolt going horizontal on the new mounts. It's a solid piece with 4 bolts going in block, and 4 bolts going in k-member. Your thinking of the other kind.
Originally Posted by mean94lt1
didnt know i had to change the knock sensor?
Here is the kind that do take a bolt through them..
http://store.summitracing.com/partde...5&autoview=sku
That will get you some good vibration in the Car.. start puttin some ladies in it also..
MADMAN'S motor mounts are a solid piece and cant be taken apart. they ONLY fit on the motor and k'member one way. take one stock one off and match it up to the madman mount and voila there ya go.
