Will this pcv system work?? PICS!!
8 sec potential, 12 sec slip
You should put the PCV valve directly attached to the intake manifold. The way you have it now, you will be boosting the catch can...
Also, you will not have any ventilation under boost either (when you need it most). Take that T out of the line, and run a hose coming from the front port on the p/s valve cover to the intake side of your turbo. Then you should be good.
