Should i get brackets for slp stage 1?
I got the slp stage 1 suspension which ive been told is springs similar to eibach prokit(made by eibach) and slp valved bilsteins. I am a bit lower than stock but nothing drastic.
btw, does anyone know what the reality drop is on this kit?
Do i need brackets?
Do i need brackets?
SLP Level 1 Progressive Springs: Front 223-448lbs/in, Rear: 97-136lbs/in, advertised drop 0.75".
Eibach V8 Prokit 98-02: Front 400lbs/in, Rear: 80-137lbs/in, advertised drop 1.25"
As far as "brackets" are you asking about LCA relocation brackets? If so, it depends on what you want out of your car. Dropping the rear mounting point of LCA's improves staight line traction but will sacrifice handling.
