warped rotors cause vibration just cruising???
there's lots of things that could cause vibration during normal cruising, which is why it's a bit difficult to find the cause (or causes).
badly warped rotors
tires not balanced (weights may have come off)
tires with flat spots/bubbles
bent rim(s)
bent driveshaft
bad u-joints
bad wheel bearings
worn out ball joints
worn out control arm bushings
worn out tie rods
worn steering rack
i'm sure there are still at least a couple things that can contribute to vibration when cruising, but that's all i can think of right off the top of my head....anyone think of anything else?
badly warped rotors
bent rim(s)
bent driveshaft
bad u-joints
bad wheel bearings
worn out tie rods
worn steering rack
Yeah i was going to ask the same question. I just got new tires on less that 1000miles ago they ran fine no issues 100+. However now i just started to notice that i get a good vibration when i am cursing and when i step on the breaks it gets some what worse.
