4000 stall tuning
Old 04-21-2007, 03:06 AM
Honda Hunter's Avatar
Default 4000 stall tuning
What specific tuning needs to be done when using a 4k stall? I'm using the stock settings and it I noticed it shifts wierd or late or to fast sometimes. There are no miss fires and the tranny is new.
Old 04-21-2007, 07:54 AM
GregWS6&z28's Avatar
are you sure you have the fluid completely filled? is your speedometer reading correct?
Old 04-21-2007, 09:18 AM
LS1Tech Sponsor
performabuilt's Avatar
Yes in many cases people who get over a 3000 stall do have to have tuning , The PCM uses engine RPM/VEHICLE SPEED and TPS and even to some exstent MAF readings to determine when to shift with a high stall all of these parameters will be different than the PCM thinks it should be seeing so basically untill the tune is set up for it , irratic shifts, odd shift timing early/late,bouncing off the rev limter/lockup issues are all comon problems untill this is done, As for what has to be done. Perhaps posting in the tuning section might serve you better.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 04-21-2007, 02:14 PM
00cls1camaross's Avatar
just got my 4000 on and it is godly!!!
my car runs 100% fine and just locks up under light throttle at 35 in D and 40-45 [D]
must be that my car is a vert haha
