High speed vibration when off gas?
I noticed this today getting on the interstate. When I load up the car and get to about 90 or so and then back out (clutch in) I get an odd vibration which feels like it is from the rear of the car. It seems to go away when it is back in gear and I load it back up. Sort of difficult to tell for sure, but that is how it seems.
Only thing I can think of would be to check the torque arm bolts and pinion angle out. I dont know if that speed when it unloads if there is too much negative pinion angle and is causing a vibration. Any ideas that would help are appreciated.
are your LCA's still stock? if so, the bushings may be worn out.
i think that's what is causing weird vibrations on my car in the same types of situations as you, when unloading the rear, and sometimes braking.
when i was under the car installing my sway bars, i grabbed my LCA's and tried twisting them, and they were both able to be twisted by hand, especially the passenger's side
i've got new LCA's on the way, so hopefully it will get rid of that, cause it's getting REALLY annoying.....
Originally Posted by WS6FirebirdTA00
Checked my pinion angle today and it was off a little bit, so we will see...
