Dynamometer Results & Comparisons - D1SC + Bolt-ons + E85 = 545rwhp
No Juice
04-22-2007, 11:52 AM
Had a fun weekend in Watertown SD. Had the car tuned by Andy, the short of it is 545rwhp/486rwtq on an 8lb kit. More details are here:
http://www.dynotuneusa.com/cornchicken
and a video
posted later
This is the first E85 (Corn) Blown F-body that we know of. Its also a flex fuel vehicle as well. The tuning was doen using a Prototype Predator Programmer. Not bad for just bolting things on a car. I also wanted to note that this is with a stock fuel pump and a Kenne Bell Boost-A-Pump.
This has completely exceeded my expectation.
Big thanks go out to rubbersidedown(Andy), morejuice(Jesse), and JUSTIFIEDC5(Ryan). Thanks fellas!
venom ws7
04-22-2007, 03:52 PM
great numbers man those D1SC are great i have a friend whos installing one in couple of weeks its cam,boltons and 8lb kit i ll post result soon.
Oh just one thing the link you postet had two dyno charts what is the diffrence between them?
thanks.
MoreJuice
04-22-2007, 07:06 PM
thanks.
The top chart is the E85 tune and the bottom one is the 91 octane chart. Just wanted to show the difference between the two.
Damian
04-22-2007, 07:09 PM
What kind of fuel pressure are you getting with the boost pump? How well did it hold pressure at peak RPM ?
TIA
Mike TexaSS
04-22-2007, 07:16 PM
E85 has a lot of promise for the future. Can you PM me the A/F ratios on E85.
venom ws7
04-22-2007, 08:00 PM
MoreJuice]The top chart is the E85 tune and the bottom one is the 91 octane chart. Just wanted to show the difference between the two.
DAMN :eek2: E85 is working great with forced induction LS1
nice numbers again now take to the track. :)
ChucksZ06
04-22-2007, 09:32 PM
Hey I used to live in that part of s.dak. Do you have a web address for the tuner in Watertown. My last name is schlekeway. Thanks.
No Juice
04-23-2007, 06:29 AM
I don't know what the AFR was on the E85, I was running the camera during those runs. I was told to not disclose that information anyways. You would have to ask the tunner.
No Juice
04-23-2007, 06:35 AM
TIA
As you can see the fuel pressure was fine on the 91 octane gas by the looks of the AFR. I'll have to ask how the pressure was throughout all the runs.
I just talked to him, the pressure stayed the same (60psi) for the 490 run. It dropped slightly on the top end on the 545 run. We think that the pump is not the problem though. We had a gauge on the rail, it might be the rail but certainly not the injectors
No Juice
04-23-2007, 06:38 AM
The track numbers won't happen until later this year. Its not really a track car, seeing that it still has the stock 10-bolt w/3.73's, stock clutch, and stock Goodyear F1's
ChevyChad
04-23-2007, 07:06 AM
I'd like to know the A/F on the E85 as well.
Nice numbers for sure :cool:
oange ss
04-23-2007, 08:18 AM
probably close to 8:1....
Tonner
04-23-2007, 08:27 AM
So you dont use the Boost referenced regulator, to lift the pressure ?
rubbersidedown
04-23-2007, 09:09 AM
stock in tank pump (with stock regulator) The boost-a-pump is a voltage booster that, when triggered (by 3 or 5 psi switch) raises fuel pump voltage to anywhere from 15-19 volts, enhancing flow by a bunch (don't know specific # off of the top of my head) they've been used on mustangs for years, and we've used them on quite a few vettes...
andy
Tonner
04-23-2007, 09:39 AM
Prolly like a Caspers volt booster, thats probably a good thing if you are using the stock stuff.
Pro Stock John
04-23-2007, 02:47 PM
More timing with E85?
oange ss
04-23-2007, 03:07 PM
probably with 105 octane
BONESTOCKC5
04-23-2007, 08:43 PM
NO JUICE,
Nice numbers, that thing should fly, or the ring gear out the diff. :jest: Hope you get some TIRES.
rons 00z
04-23-2007, 10:33 PM
when are you going to use e-85?
Grimes
04-23-2007, 11:08 PM
lol at the chopped pics of you car. E85 should spread more as ethanol production rises. I'd really like to tackle a project like this.
JUSTIFIED C5
04-24-2007, 05:13 PM
It was a fun weekend, very impressive numbers. Congrats again Justin. Like Bonestock said, your gonna need some tires...
Ryan
green28
04-24-2007, 05:55 PM
I knew there was a good reason my car has John Deere colors. Putting down some very nice numbers I like the combo. Gonna have track times any time soon?
fact9c1
04-25-2007, 12:02 AM
nice numbers
Nice work... E85 is the shit.
Trail 70
04-27-2007, 12:42 PM
Justin, I think I still have you with the COBRA.... Nice numbers.. 12sec timeslips..... no more 13... See-ya
Irocss85
04-27-2007, 07:09 PM
congrats on the #s, this is exactly the type of thing Ive been hoping would happen. if I had the knowhow to tune, Id def/ be trying to figure this stuff out. very curious about how you got it to be flexfuel. so you can have half tank of 91, and half tank of E85 and it will run good still? or do you mean you have two diff. programs you can load into the pcm with the tuner to run on either? we still dont have very many E85 stations here in michigan, so it'd be kindof hard to have it E85 only. how have you gotten around the "30% more fuel" issue? holding the inj.s open longer by somewhere close to 30%, or is the fuel press. jacked up with the volt blaster when on E85, or what?
its too bad your tuner doesnt want to share what he's learned so far with the class. cause thats whats gotta happen for people to start experimenting themselves and make this stuff more widely used. and as soon as its more widely available, and used, it'll be cheaper and they'll put in more pumps across america. its a big pyrimad affect that needs to start with people sharing information.
rons 00z
04-28-2007, 12:34 AM
no doubt tell your tuner to spill the beans!
