Did the full Tropi Care treatment on my TB SS
I bought the trial kit a while ago so today I decided to give it a full treatment.
First I used the wash and moved on to the swirl cutter. For the swirl cutter I used my PC 7424 on speed 5 with a white pad. Then I moved on to the sealant and finished it with the detail spray.
Overall, the product is very easy to use and remove. From start to finish it took me about 2 hours. My only complaint is both the swirl cutter and sealant are a little too thick and is hard to get a smooth spread (both pads were misted with water). So I added a little water to both product containers with okay results.
Here are some untouched pics taken in the garage and outside with cloud cover.
