turbo questions ...look inside
Old 04-22-2007, 07:17 PM
tomulrich's Avatar
Default turbo questions ...look inside
can a non ball bearing turbo be converted to a ball bearing type. Specifically a Precision type 66mm.
Also what is exceptable shaft play on a 3000 mile turbo?
Will a ball bearing turbo last longer than a jounal stlye turbo?
Thanks
Old 04-23-2007, 08:41 AM
LS1TECH Sponsor
DrTurbo's Avatar
The turbo itself using the parts you have can be converted, but would be very $$$. Cheaper to buy the DD CHRA and swap the end housings with it. Also as for longevity...well they both will last for a LONG time if they are properly built and serviced with frequent oil changes.
