cc305 vs cc503
cc305 vs cc503
looking at the specs at these two, what is the difference? the duration and lift is close, but one is 112 lsa and one is 114 lsa. what is the difference in 112 and 114? looking for a good cam for a bolt on stock headed car, and ive decided to go with something better than a hotcam. i want a cam that will sound good, but will give good numbers. also i heard something about one of them you have to change out valve springs ever 20k miles, cant remember which one though. any info will be greatly appreciated.
im pretty sure im going with the 503, been reading some good things on it in the past few minutes, someone said it in another post somewere, i think it was the cc305, but i cant remember, lol.
i have a cc503 with crane 10308 valve spring kit, comp hi tech PR's, stock lifters, and GMPP 1.6 RR. the set up works quite well and sounds good and runs strong. it's a great cam for stock heads, however i have heard it really wakes up with a set of heads. i'll know for sure next weekend when i install a set of GTP heads on my car. i can get you a sound clip of my car at idle if you are interested in hearing what it will sound like.
yea, thatd be great!
Originally Posted by 95greenZ
The 112lsa on the 503 will lope better than the 114lsa.
going from a hotcam to a 305, you wouldn't see much of a difference- if any, in sound.
think about it 218/228, .525/.525" on a 112, vs 220/230, .510/.510 on a 114.
the *slight* bit of extra duration will more than be muffled by the extra 2* in LSA...
I've got a 503 on 1.6's in my car, absolutely LOVE the sound, and can't argue with the torque either... idles great, even at 800rpm.
go with a 503, you won't be dissapointed
