Anyone notice harder shifting after Mobil1 trans fluid?
Anyone notice harder shifting after Mobil1 trans fluid? Just me?
Maybe it's me, but I've had a harder time getting it into gears since changing to the Mobil1 ATF. It could just be my imagination, but the fluid that came out looked brand new. I'm beginning to think my buddy with a shop was right when he said run the cheapest trans fluid you can get, just change it on time.
if anything, going to a thicker dexron 3 generic fluid only made a difference when cold for my transmission. Even then, it only felt a bit more notchy. For the life of me I can't tell the difference between oem dexron 3, amsoil, mobil 1 etc. Next change I'll just go with mobil 1.
I ran the regular ole dex III in mine for several thousand miles. Last weekend went to our local LS1 shop and was talking to the owner about it as they are one of the ones that even recommended reg tranny fluid. He told me they had been using Royal Purple in the T56's and had really good luck and reviews with it.
I changed mine out due to the notchy shifting, it is 10x better now as the tranny shifts smoother than it did under the original factory tranny.
I am running a Lou's short stick and the factory Hurst shifter and it shifts great now.
