Generation III Internal Engine - G5x3 or G5x4
View Full Version : G5x3 or G5x4
W8S SS
04-23-2007, 06:58 PM
Like the title says. I was told I could fit the x4 under stock heads and it's on 111lsa and I want that lopey sound. What do you guys think? I want to see 4xx/4xx cam only :devil: and I know these cams will do it but which one would suit me better? I'll be putting heads on about 6 months down the road. Thanks
DONAIMIAN
04-23-2007, 11:00 PM
If all your trying to do is hit 400/400 you can do with cam only. I hit 400/395 with a 221/221 112lsa cam. Didnt have to rev the motor way out either. My idle was set at 900 because of my AL flywheel, but but you could still deff. tell it was a cam in the car.
ExceSSive
04-24-2007, 07:21 AM
Is this the big secret cam??? You still gonna be slower than the rest of us in the group except maybe Jamie.
Patrick G
04-24-2007, 08:25 AM
Both of those cams will get you over 400 rwhp with the right bolt-ons, but don't expect to be over 400 lb ft of torque. Very few cam-only vehicles hit that. Typically, it takes a large jump in static and dynamic compression to do that (think ported heads). As mentioned above, you can definitely hit those numbers with a smaller cam and you may not have to spend so much time on the drivability tune.
01Z0H6
04-24-2007, 05:43 PM
I was able to do it... Barely...
My LS6's are unported... for the record... I plan on some good ported heads and a FAST 90 90 set up possiblt this summer.. But for now... I'm good...
http://img402.imageshack.us/img402/433/js640dynolgmad4.jpg
30th t/a
04-24-2007, 08:51 PM
like I said, go for the X4. I had the X3 on a 112 & the X4 111 and I cant even tell the difference between the 2 except the X4 has a little more pull on the top end. Both drive great......as long as the tune is great.
