Hypertech Programmer for sale
I have a Hypertech Programmer Part # 380752 / 30028 that I bought and never used let me know if you are intrested. I'm asking 180 for it.
I bought plugged it in but never changed anything around.
You will never get more performance or tuning options for less money, and less trouble. This unit works perfectly, and is in excellent condition and is sold as is. It comes with original box, programmer, cable, instruction manual and decals.
If you decide to change anything, it's just a press of a button to change it back to stock, or do more programming.
You will notice an immediate performance increase.
Hypertech Power Programmer III
Hypertech Power Tuning
Tunes the engine for maximum power and performance, plus potential gas mileage improvements
Three-Stage Power Tuning
Special Three-Stage Tuning for Select Vehicles
Dual Fuel Tuning
Lets you choose optimized tuning for 87 octane or 93 octane fuel
Engine Rev Limiter
Extends the engine's RPM range for a wider power band
Cooling Fan On/Off Temperatures
Permits use of low-temperature thermostat for cooler, denser intake charge and lower engine operating temperature
Transmission Shift Points
Optimizes shift points by speed and RPM for maximum acceleration
Transmission Shift Firmness
Firmer full-throttle gear changes for faster acceleration
Top-Speed Limiter
Allows the vehicle's top speed to be matched to the speed rating of factory-approved high-performance tires
Speedometer/Odometer Correction
Automatically corrects speedometer and odometer readings for non-stock tire sizes and/or non-stock rear-end gear ratios (accurate odometer readings are required by law)
Read and Clear DTC's
Diagnostic Trouble Codes
Hypertech Power Programmers for different year, make and model vehicles, may contain different programming features. While all vehicle computers control spark advance and air/fuel ratios, some computers also control cooling fans, torque converter lock-up points, transmission shift points, top speed limiters, rev limiters, etc., but some vehicle computers do not. Hypertech endeavors to take advantage of all performance related features possible, for all computer controlled vehicles, but not all features are always available in some Power Programmers and are noted with an N/A.
Hypertech Power Programmers contain tuning programs which optimize spark advance and air/fuel ratios to produce maximum performance. For higher performance engines (with higher compression ratio's or superchargers or turbochargers) designed to use premium gasoline (93 octane), Power Programmers contain tuning for premium fuel only. To attempt to use lower octane fuel could result in detonation and possible severe engine damage, and is never recommended.
For standard performance engines (with more modest compression ratio's and without superchargers or turbochargers) Hypertech Power Programmers contain two optimized tuning programs...one for regular 87 octane gasoline, and the other for 93 octane gasoline (Dual Fuel), giving you the option of maximum performance and cost savings, or absolute maximum performance, period, for competition or perhaps heavy towing situations.
Item will be shipped USPS 2 to 3 day Priority mail as soon as I receive payment, PayPal ONLY please.
Dual Fuel Tuning
Engine Rev Limiter
Top-Speed Limiter
