Few passes from yesterday
Old 04-23-2007, 10:35 PM
kp
kp's Avatar
Default Few passes from yesterday
Nothing too exciting really, about 80 degrees out and had a bunch of timing out (14 degres peak) and running the car a lot richer (11:1 or so) and got it slowed down to 9.40s. Max around 14psi of boost. Doing a couple 9.50 index races soon, I will say its a lot easier to slow it down then make it go faster Who says a blower car cant be consistant, 9.46 @ 145.3, 9.43 @ 145.7 and 9.42 @ 145.7..
http://video.ls1tech.com/video/2962d...190131853d.htm
Old 04-23-2007, 10:47 PM
quicksilverado's Avatar
Nice to meet you yesterday Kevin. Car looked great and you made those times look easy.
Old 04-23-2007, 10:52 PM
Navy David SS's Avatar
Very nice runs. Straight and true. Are you able to lower the boost to make your 9.50 or will they allow .10 difference? What was your 60's. Again nice set-up. Water push days over ?
Good luck.
Old 04-23-2007, 10:53 PM
kp
kp's Avatar
Same here, good talking with you. I dont know if it looks easy or looks slow in those videos
Old 04-23-2007, 10:57 PM
kp
kp's Avatar
Good luck.
It wont push any water when its warm out, power drops off pretty hard. I figure it will be a little warmer when I really race it so it should be right at 9.50.
Yesterday the 60 foots were 1.310 or so, they take a dive when it gets hot out - not too much I can do about it with an A2A intercooler.
Old 04-24-2007, 06:42 AM
cablebandit's Avatar
nice runs Kev!! Folks had no idea what you could have run had you wanted to You made it look easy to run those 9.4s I did not know it was THAT hot out....i did get some sunburn on my arms. Black car with black interior and firesuit...80 deg must have seemed like a/c when you got out of the car!!
Old 04-24-2007, 07:41 AM
kp
kp's Avatar
The TAG said 2500' DA and 85 degrees but thats with the sun heating everything up. Real air temp was around 79 most of the day and the weather wasnt that bad with a nice breeze. You dont see me running much when it gets above 85 and the humidity goes up, it gets hotter then hell in the car, then add a 3 layer jacket, pants and gloves and it takes a lot out of you. Thats why I do most of the work on the car in July and August, air conditioned garage and its too hot for me to sit in that stupid car
Old 04-28-2007, 05:57 PM
NASTY98TA's Avatar
Default F1a
Whats going on with the F1A,, Waiting to do a big motor?
Brian
Old 04-29-2007, 12:05 AM
kp
kp's Avatar
Brian
Not bigger necessarily, just fresher. This 346 has nearly 300 passes and why kill it now. I may grind the bracket a little and try a 4.25 pulley on the F1A, 20psi with the 4" pulley is a little much.
But its 'real' racing season and not timeslip racing season so all I have to do is get it to run 6.0 in the 1/8 or 9.50 in the 1/4 which is no problem for the D1. Matter of fact I just came back from an 1/8 mile 6.0 heads up index race and ran a 6.001 and a 6.010, then slept at the tree and lost first round with a 5.96 @ 118 trying to catch the other guy, thats racing..
Old 04-29-2007, 07:22 AM
damn Kev you had it dialed in for 6.0 ....what were your 60'?
Old 04-29-2007, 08:45 AM
kp
kp's Avatar
1.38x or something, I had it really turned down and the 2 step at 2000. That works to slow it up a little but kills my reaction time. A .100 light on a .400 pro tree wont get you far when the other guy runs 6.00
Old 04-29-2007, 09:01 AM
7 Second Club
ty_ty13's Avatar
thats odd that your converter acts like that... usually on dads car if i give it more space between the 2step and the converter's stall rpm it hits harder... on his bracket car we only give it a 200 rpm "run at it" to try and soften the 60ft :shrug:
every car is ALWAYS different...
Old 04-29-2007, 12:43 PM
kp
kp's Avatar
At 3500rpm the car wll react a lot quicker, 2000rpm is pretty weak off the line on mine. Depends a lot n the car as well, a heavy stock suspension car just isnt going to react as quick as a light 4 link car. My car is perfect on a .500 pro tree with an .020 delay but a .400 is rough - I'm getting old too and just dont do a lot of pro tree stuff anymore..
Old 04-29-2007, 02:32 PM
Torchvette10's Avatar
Nice vids!! Impressive car!
Just a question, who built your 347?
Old 04-29-2007, 03:24 PM
iB2slow's Avatar
Awsome car to say the least I remember seein it at the track runnin 10.0 9.8 or so but that was a WHILE back.
Old 04-29-2007, 07:17 PM
kp
kp's Avatar
W2W did the short block, close to 300 HARD passes now and its still running very well. Going to retire it soon though.
iB2slow, I havent been to BG in a while, weather was crappy early this year there I'll probably go for the NMCA race this coming weekend..
Old 04-29-2007, 10:17 PM
iB2slow's Avatar
Yeah I havent been in close to two years, track needed some major work between the water box staging beams the last time i was there. I had HEARD they was going to concrete the 1/8 hearsay though i assume. I might come and check out your ride if im home, its came ALONG way since if seen it. It was wild though couldnt hardly hear the car run and it rip off high 9's.
Old 04-29-2007, 11:36 PM
obZidian's Avatar
Where those runs played at half speed?
Old 04-29-2007, 11:56 PM
kp
kp's Avatar
Its just as quiet now, now but it runs low 9s. The times in this post are from trying to slow the car down to 9.50s, it been 9.13-9.17 quite a few times.
They supposedly redid the whole track last year, the pic in my avatar was from october last year and it sure was hooking. It didnt seem that much different but they supposedly did concrete to the 1/8.
obZidian, here is the first pass from a slightly different perspective, looks a little quicker.
http://s91.photobucket.com/albums/k3...t=100_0323.flv
Old 04-30-2007, 01:24 AM
iB2slow's Avatar
Yeah i knew your car was runnin low 9's now I looked at your site a while back and read you switched to the AFR's back to the D1 and ran quicker (I believe thats right).
Like i said i havent been to the track in a long time, sold my 02 z28 bought a notch back more of a race car and it pretty much made me loose intrest for a while was quick just a headace. Its ok though because im partin that bitch out now to get back in another f-body.
Quick Reply: Few passes from yesterday
