amp the front speakers ??
does anybody have a installation guide on on to amp the front door speakers ? I just bought a set of:
Lanzar OPTI62
RMS Power Range : 200 Watts
Peak Power Handling: 400 Watts
Impedance: 4 Ohm
Frequency response: 55-22000 Hz
Design: 2 Way
for the front and was wondering how I would hook it up to a
Sony XM-554ZR
Channel(s)
4 Channel(s)
Output Power
4 x 55W RMS @ 4 Ohm
4 x 65W RMS @ 2 Ohm
1 x 130W RMS @ 4 Ohm - Bridged
Maximum Power
600W .........................................
Please help thanks
Lanzar OPTI62
Impedance: 4 Ohm
Design: 2 Way
Sony XM-554ZR
Channel(s)
4 Channel(s)
Output Power
4 x 55W RMS @ 4 Ohm
4 x 65W RMS @ 2 Ohm
Maximum Power
Please help thanks
bridge both channels and run a sub with the rear unless you bought two sets of speakers and have 4 total. Then just both bridged for the fronts.
You need to decide where you want to put your amp. You need a power supply for it. (12v+ fused from the battery). Your amp should have instructions as well. You'll need to run speaker wire from the amp to the speakers. You need to run cables and a trip wire from the Hu to the amp. You've got a lot of work ahead of you to do it right.
Originally Posted by homerunhtr21
can somebody tell me what a decent priced amp would be? I have had this one for a while and it seems to do fine, never overheats, nothing but everybody tells me they suck
Phoenix Gold.
-depends how much you want to spend and on the amp -- not sure what you mean by "decently priced" -- I assume you meant as cheap as you should buy without sacrificing quality entirely.
