Are these heads any good ? (flow chart included)
Originally Posted by Stang's Bane
...the numbers look good.
There probably is an application for these heads, but for the steet I'd try and snag something with some better low-lift numbers. Also, with this being said, keep in mind that flow numbers aren't the end-all for a cylinder head comparison. There are too many variables that don't easily show up on a bench, and there is the possibility of operator error. If the bench operator doesn't get the geometry right for the valve opening then the numbers will be messed up.
Ben T.
LS1 Tech Administrator
Surprisingly, your best performance comes from airflow in the .300-.500" range. The numbers at .300" and .400" are especially important. For this reason, I would say your porter was trying to impress you with a high peak number, but the real world performance on the heads is going to be average at best.
For what it's worth, the top ported cylinder heads (TFS, ETP, AFR) flow in this range on a 3.900" bore:
.200" 150-158
.300" 217-220
.400" 261-264
Look at yours. They're down about 20-25 cfm. This is a case where spending more will get you more.
.200" 150-158
.300" 217-220
.400" 261-264
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Originally Posted by Studytime
I'm going to have to disagree with that. I don't think they are that wonderful. The last set of 2.00"-valved 853s I ported that went on a flow bench flowed 210 cfm @ .300" (yours are at 189cfm). Granted yours are flowing ~300 @ .600" lift, but low-lift numbers look soft on these.
Ben T.
Ben T.
Even if worked for a solid-roller with .650" + of lift, there is still power to be had with stronger midlift numbers, but I do see where you are coming from. Keep in mind the fact that you see peak lift once, but mid and low lifts happen twice for each valve event.
The best way to evaluate these heads (if the quality of port work is up to par) is to bolt them on and go racing. Let that have the final say in how they perform.
I'd take a cylinder head that has strong low-lift and midlift numbers ANY day over a head with just good peak lift numbers. I'd even perfer it if the port did go on to backup at, say, .600".
I'd especially pick mid & low lift numbers over peak when using the LS6 intake.
Ben T.
Ben T.
Amen, to the take it to the track. Flow bench numbers don't win races
__________________
All I was saying is that just looking at flow bench numbers is only part of the story behind a good set of heads. For all we know he could be using a big solid roller and a single plane intake. He also may have paid $500 for them, so he did get a good deal if that was the case. Like you said you get what you pay for most of the time.
Patrick, I already stated I would get something with better lowflow numbers. I was trying to be polite if for his sake.
Don't forget the as-cast Dart 205s break the correlation you just mentioned. They have poor low flow numbers, actually backup at like .550" lift, but make really good power.
Ben T.
Ben T.
Ben T.
Ben T.
I'm a fan of the Dart heads.
__________________
Originally Posted by b005td
try to see if i spent my money wisely
thanks
thanks
Is there anything he could do with cam selection to help out?
Originally Posted by Spellbound
Looks like he already bought them.
thx so much for the advise guys
actually i havent got them yet, typo there
from the info here, looks like i wont be getting those heads, thx guys, may be get some TSP / AFR / Dart down the road
i already have a TR230 / 224 cam
i should have put that in my sig or something
edit : but if anybody wanna get these heads for $900 pm me, i'll get u contact info of the seller
Originally Posted by Patrick G
Ben, I totally agreed with the two posts of yours above. And for what it's worth, the Dart 205s I've seen had above average low and mid-lift flow due to the excellent valve jobs. This is the main reason why they make big power (since the higher lift flow numbers are average). I feel like we're saying the same thing.
My set was certainly not above average or even just plain ole average.
Here's a thread I made about them,
https://ls1tech.com/forums/generation-iii-internal-engine/513445-had-set-dart-205s-bench-morning.html
Intake, 205 cc port, 2.02i & 1.60e valves;
.050 _34.8
.100 _69.6
.150 101.3
.200 127.1
.250 154.6
.300 181.7
.350 206.2
.400 231.5
.450 250.9
.500 265.5
.550 274.0
.600 279.4
.650 263.8
.700 265.6
.050 _34.8
.100 _69.6
.150 101.3
.200 127.1
.250 154.6
.300 181.7
.350 206.2
.400 231.5
.450 250.9
.500 265.5
.550 274.0
.600 279.4
.650 263.8
.700 265.6
I agree we're making some of the same points as well.
Ben T.
It just goes to show you that the flow bench doesn't mean everything.
Ben T.
...and PRC's 237cc intake runner LS6 heads that still make good low-speed torque, GM offering 260cc L92 heads on a freakin' heavy SUV. Some of this stuff makes me scratch my head. You think you start figuring it out, and then this comes along. Repeating the term "flow quality" makes me feel better about it although I don't fully understand.
Ben T.
Ben T.
there a guy here in town saying he got a set of ported / reworked 5.3 heads and will sell for 1100 and he said the flow numbers are exactly same as the AFR 205. i know that the guy that did the rework was very reputable in town. but what else i need to look for ?
