m6 to a th400
Old 04-24-2007, 06:41 AM
02fastbird's Avatar
Default m6 to a th400
do you have to make the speedo work.
Old 04-24-2007, 07:15 AM
8a8mfh's Avatar
I don't know why you wouldn't. most late 80's truck th400's in both long and short tail came with electric sending units that your harness will plug right into.
Old 04-24-2007, 11:12 AM
98turbls1's Avatar
will the Speedometer Drive Sensor Rotor work from those too??
Old 04-24-2007, 12:03 PM
8a8mfh's Avatar
Yes it should as long as it gives the same pulses per revolution. If not that can be changed with programming.
So you need the reluctor wheel and sensor off a mid 80's truck or van.
There are two different reluctor wheels, one for the small/long shaft and one for the 32 spline/short shaft. They have different inside diameters.
Old 04-24-2007, 12:23 PM
98turbls1's Avatar
Cool man... I need the one for the short shaft... Thanks for your help..
Old 04-24-2007, 02:30 PM
Race your car!
JL ws-6's Avatar
you don't "have" to make it work, but the cruise won't work without it hooked up. TCS/ABS still work without the speedo hooked up.
Really up to you.
Old 04-24-2007, 03:56 PM
02fastbird's Avatar
thanks.i just dont want to spend the money to make it work right now. we're just trying a new set up.thanks for the response.
