Best plugs for a turbo setup
Old 04-24-2007, 07:44 AM
Dbluegoat's Avatar
Default Best plugs for a turbo setup
I know this is probably somewhere but teh search button around here is a pain
What would be the ideal spark plugs for a 8.9 compression turbo setup?
thanks
Old 04-24-2007, 10:20 AM
cablebandit's Avatar
how much boost?
Old 04-24-2007, 02:17 PM
Dbluegoat's Avatar
less than 20......hopefully around 15 most of the time
Old 04-24-2007, 03:17 PM
Navy David SS's Avatar
I run NGK-8's
David
Old 04-24-2007, 03:33 PM
7 Second Club
Phil99vette's Avatar
Which NGK 8s do you run? Projected or non projected tips?
Old 04-24-2007, 07:27 PM
Pathological Modifier
Ryan K's Avatar
Autolite Racing (like NASCAR) AR94's here best plug I have ever ran.
Old 04-30-2007, 12:56 AM
ttcamaro's Avatar
i have run the same plugs on my car forever, AC R42lTS. made 1200hp with them. The buick guys have used them as well. Not sure if ls1 plugs are diff though
Old 04-30-2007, 06:10 AM
Cal Hartline's Avatar
From what I have seen they both take the same plugs. The Buicks use R42TS on the tamer combinations. Most of the hot street cars use Autolite 103's. The faster race cars use Autolite 3294's
Old 04-30-2007, 08:52 AM
Nmbr1GMfan's Avatar
Jason, Street usage we use TR-6 for mild boost (8-9 psi) and TR-7 for moderate boost (10-13 psi) and TR-8 for higher boost (14+). TODD
Old 05-07-2007, 09:35 AM
trans2000am's Avatar
what gap for tr6's
Old 05-07-2007, 09:41 AM
ibgoatin's Avatar
Jason, I used TR6's gapped @ .032 with 12#'s of boost
Old 05-07-2007, 10:27 AM
NA$TY-TA's Avatar
Ive used TR-6's @ 20 psi, but im about to go a lil colder.....
Old 05-07-2007, 11:38 AM
Vindication's Avatar
Why doesnt anyone try the HKS spark plugs?
Old 05-07-2007, 02:09 PM
NA$TY-TA's Avatar
How much are they?????
If there over $4 each i wont even bother.... ill stick with my $2 plugs.... they work
Quick Reply: Best plugs for a turbo setup
